DIY Kit #1
2009-12-01 by Nick
2009-12-01 by Nick
Hi I am about to install the first of several DIY Kit #1s. Does it matter which way around I connect the 15v cables from the transformer to the power supply board? I'm in the UK, if that makes any difference. Cheers, Nick
2009-12-01 by yahoo@doepfer.de
> Hi > > I am about to install the first of several DIY Kit #1s. Does it > matter which way around I connect the 15v cables from the > transformer to the power supply board? I'm in the UK, if that > makes any difference. > > Cheers, Nick The polarity does not matter because it's AC. Best wishes Dieter Doepfer
2009-12-01 by Nick
Thanks Dieter Am I also correct in thinking that on the busboard I can connect the leads to the terminals on the right hand side rather than those in the middle, as in the instructions illustration? (These might seem like silly questions, but the depths of my ignorance in such matters are profound.) Cheers again, Nick --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > > Hi > > > > I am about to install the first of several DIY Kit #1s. Does it > > matter which way around I connect the 15v cables from the > > transformer to the power supply board? I'm in the UK, if that > > makes any difference. > > > > Cheers, Nick > > The polarity does not matter because it's AC. > > Best wishes > Dieter Doepfer >
2009-12-01 by Sandy Brain
either is fine i have some attached to middle and others to the side sandy On 1 Dec 2009, at 18:03, Nick wrote: > > > Thanks Dieter > > Am I also correct in thinking that on the busboard I can connect > the leads to the terminals on the right hand side rather than those > in the middle, as in the instructions illustration? > > (These might seem like silly questions, but the depths of my > ignorance in such matters are profound.) > > Cheers again, Nick > > --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > > > Hi > > > > > > I am about to install the first of several DIY Kit #1s. Does it > > > matter which way around I connect the 15v cables from the > > > transformer to the power supply board? I'm in the UK, if that > > > makes any difference. > > > > > > Cheers, Nick > > > > The polarity does not matter because it's AC. > > > > Best wishes > > Dieter Doepfer > > > > [Non-text portions of this message have been removed]
2009-12-01 by Nick
Thanks Sandy Nick --- In Doepfer_a100@yahoogroups.com, Sandy Brain <sandybrain@...> wrote:
> > either is fine > i have some attached to middle and others to the side > > sandy > > On 1 Dec 2009, at 18:03, Nick wrote: > > > > > > > Thanks Dieter > > > > Am I also correct in thinking that on the busboard I can connect > > the leads to the terminals on the right hand side rather than those > > in the middle, as in the instructions illustration? > > > > (These might seem like silly questions, but the depths of my > > ignorance in such matters are profound.) > > > > Cheers again, Nick > > > > --- In Doepfer_a100@yahoogroups.com, <yahoo@> wrote: > > > > > > > Hi > > > > > > > > I am about to install the first of several DIY Kit #1s. Does it > > > > matter which way around I connect the 15v cables from the > > > > transformer to the power supply board? I'm in the UK, if that > > > > makes any difference. > > > > > > > > Cheers, Nick > > > > > > The polarity does not matter because it's AC. > > > > > > Best wishes > > > Dieter Doepfer > > > > > > > > > > > [Non-text portions of this message have been removed] >
