Doepfer
Re: [Doepfer_a100] Re: A-143-4 Quad VCLFO/VCO
2010-01-10 by davevosh@aol.com
In a message dated 1/10/2010 2:10:42 AM Pacific Standard Time,
grimshaw@stugrimshaw.com writes:
i  think david s. meant an additional module, is that so david? i
personally  would love to have little suite of circuits to turn one waveform into
another.
stu
stu,
yes, i`m sure david meant as a separate module and, again, interesting in
the abstract but starts adding complexity to the simple idea - basic
hi-density  multi-vco module. if nothing else, there are several wave modifier
modules  available if desired tho none, to my knowledge, in a quad format.
best,
dave
RE: [Doepfer_a100] Re: A-143-4 Quad VCLFO/VCO
2010-01-11 by david.salter@thomsonreuters.com
yes Stu, I did mean a separate module, so you can use or not if you
don't want to.
At it's simplest it's a 6 or 8hp module with 4 inputs (plus a through
socket for each so you still have your triangle waveform available) and
8 outputs say rising ramp and falling ramp for each input, or for a
socket and a shape pot that goes from rising ramp to triangle to falling
ramp.
Dave, you right there are plenty of wave modifiers about, however there
is nothing for someone building a quad based system.
David
David Salter
Senior Consultant
SSG UKI
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
thomsonreuters.com <http://thomsonreuters.com/>
P Please consider the environment before printing this e-mail
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of davevosh@aol.com
Sent: 10 January 2010 10:28
Subject: Re: [Doepfer_a100] Re: A-143-4 Quad VCLFO/VCO
grimshaw@stugrimshaw.com <mailto:grimshaw%40stugrimshaw.com>  writes:
waveform into
another.
stu
stu,
in
modifier
format.
best,
dave
This email was sent to you by Thomson Reuters, the global news and information company.
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Thomson Reuters.
