Re: AW: [Doepfer_a100] doepfer at namm 2010 - ?
2010-01-25 by davevosh@aol.com
In a message dated 1/25/2010 5:06:24 AM Pacific Standard Time, yahoo@doepfer.de writes: > suspect i`m in the minority but i`d have preferred something more "controller" > and less "sequencer" from the touch unit but we`ll see what, if anything, emerges. At first the touch keyboard is only a unit that transmits the information which pad is touched (nothing but Midi note on/off). This information can be used to drive e.g. a control module that outputs e.g. a single gate or trigger signal for each pad (e.g. with LED display), one or more CV outputs (equally tuned or with adjustable voltage for each pad) and many more. Or it can be used to control a suitable sequencer unit. My idea is to have a separate box (not a module) that is connected to the control/sequencer module by a cable (like the A-198 manual). If desired the box can be mounted as a module too (e.g. by means of a blind panel with a cut-out that fits to the box). dieter, f.w.i.w., i`d like to see a "module" for the circuitry and a separate "manual" ala a-198. good luck ! best, dave [Non-text portions of this message have been removed]
