Re: AW: AW: [Doepfer_a100] doepfer at namm 2010 - ?
2010-01-25 by davevosh@aol.com
In a message dated 1/25/2010 9:57:06 AM Pacific Standard Time, yahoo@doepfer.de writes: That's similar to our plans. But the "manual" has to include the basic circuitry for the touch sensing because it would not work to wire the pads over a long distance and then detect the touch in a remote circuitry. On top of the "manual" pcb will be probably only the pads, the (smd) circuitry will be on the bottom of the pcb as well as the connector (maybe miniature USB) that is used to establish the connection to the A-100 adapter module. dieter, sorry, when i said "circuitry", i was thinking of the i/o ala a-198. i understood that the actual controller circuitry would be contained in that unit. best, dave [Non-text portions of this message have been removed]
