Doepfer
iPad
iPad
2010-01-28 by Monroe Eskew
I was thinking that the forthcoming "iPad" from Apple could be used as
an instrument similar to Doepfer's ribbon controller or the Haken
Continuum.  One would just need to program the right app.  It would be
great if a midi output cable could be created to go along with it.  I
know there are currently some synthesizer and sequencer apps for the
iPhone, but I don't know if any has taken advantage of continuum-like
effects.  The iPad would be great for this as it would be a much
bigger playing area.
Re: [Doepfer_a100] iPad
2010-01-28 by Mikhail Novikov
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I don't think there is even a USB port on iPad. How would you output it?
And certainly it would be cheaper to buy touchscreen and doepfer MIDI Electronics, than expensive and probably useless otherwise device.
BR, Mikhail
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkthOB0ACgkQPHyh4sfuKrmRVACeIkPbNLjArGkQVbsIHWIJqw8Y
j/AAn3ujrsinXZdUvurGS/JEFO54JQRl
=DQ7T
-----END PGP SIGNATURE-----
2010-01-28 by Mark Pulver
There's a pigtail cable that gives you a USB port.
Development for the iPad will be TIGHTLY controlled by Apple, and remember,
it's basically just a huge iPhone. It does _not_ multitask.
 >Hash: SHA1
Cheaper to buy a touchscreen?  Can you provide evidence?
On Wed, Jan 27, 2010 at 11:09 PM, Mikhail Novikov <freiksenet@gmail.com>wrote:
> Hash: SHA1
> BR, Mikhail
> =DQ7T
RE: [Doepfer_a100] iPad
2010-01-28 by david.salter@thomsonreuters.com
A touch screen would probably work out cheaper, however the iPad is a
multi touch screen which with OSC will provide a better experience IMHO
David Salter
Senior Consultant
SSG UKI
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
thomsonreuters.com
P Please consider the environment before printing this e-mail
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of Monroe Eskew
Sent: 28 January 2010 17:00
Subject: Re: [Doepfer_a100] iPad
> Hash: SHA1
it?
> BR, Mikhail
> > as an instrument similar to Doepfer's ribbon controller or the Haken
> > continuum-like effects. The iPad would be great for this as it would
> > be a much bigger playing area.
> =DQ7T
Yahoo! Groups Links
This email was sent to you by Thomson Reuters, the global news and information company.
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Thomson Reuters.
Hash: SHA1
Even kaosspad costs less that iPad, plus there are plenty of OEM touchscreen manufacturers that are definitely cheaper that iPad, cause they come with no software and smug cloud :) I was talking about this.
> BR, Mikhail
iEYEARECAAYFAkthxVEACgkQPHyh4sfuKrnZzACfelTx/jr+srDvOI8lu7DFb2Fo
uUgAn0OHcX2rsvSt1TM4O3ioPeHLyhFp
=i5k6
2010-01-28 by Kasper T Toeplitz
only 1 point as opposed to the multitouch iPhone (or iPad?)
2010-01-28 by james.husted@mac.com
I use the iTouchMIDI suite of programs - http://www.itouchmidi.com/ - and they have a Mackie Control Universal emulator that works fine with Ableton and Logic etc. They also do the standard Keyboard and Pad and Kaos Pad emulations too, They should work straight out of the gate with the iPad but I want to see what people write for the iPads larger surface. I assure you there will be plenty of music apps. All will connect to a host machine via wireless though which is cool for me. Leave the heavy lifting (and Audio interfaces) for the host machine and give me a control surface with NO wires. You will see Lemur clones and Tenori-on clones and APC-40 clones in no time I'm sure.
James Husted
www.synthwerks.com
thesynthwerks@gmail.com
synthwerks@me.com
