too many volts on the a132-3?
2010-02-08 by Greg Cerveny
Hello all, I had my orb sequencer gating @ + 12v into an a142 into an a132-3. Now the top vca is not responding consistently to cv signals. The gain works fine. The bottom vca works fine. I see the 132-2 accepts -8 to +8. Did I put too much voltage into it?
2010-02-08 by Bakis Sirros
or, maybe, you sent too many volts into the trigger input of the 142... and the decay envelope has a problem now...? does the top vca of the 132-3 work fine with other cv sources, apart from the 142? the 132-3 vca's accept up to +/- 8 volts without distortion, in the audio input, that does not mean that if the audio signal is higher the vca's will be destroyed.... btw, why would you have your ORB send a +12 volts gate, anyway? are you triggering Roland envelopes from it, as well? Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com www. shimarecords. co. uk --- On Mon, 2/8/10, Greg Cerveny <greg.cerveny@gmail.com> wrote:
Subject: [Doepfer_a100] too many volts on the a132-3?
To: "doepfer_a100" <Doepfer_a100@yahoogroups.com>
Date: Monday, February 8, 2010, 7:38 PM
Hello all,
[Non-text portions of this message have been removed]2010-02-08 by Greg Cerveny
The orb defaults to a 12v trigger. I need see if I can adjust it. Oy... I'm an idiot. When trying out other envelopes, I realized that it was the cv attenuator that was the problem. I gave it 100 rotates and now it's working. On Mon, Feb 8, 2010 at 10:55 AM, Bakis Sirros <synth_freak_2000@yahoo.com>wrote: > > > or, maybe, you sent too many volts into the trigger input of the 142... and > the decay envelope has a problem now...? > > does the top vca of the 132-3 work fine with other cv sources, apart from > the 142? > > the 132-3 vca's accept up to +/- 8 volts without distortion, in the audio > input, that does not mean that if the audio signal is higher the vca's will > be destroyed.... > > btw, why would you have your ORB send a +12 volts gate, anyway? > are you triggering Roland envelopes from it, as well? > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > > [Doepfer_a100] group owner > > www. parallel - worlds - music. com > > www. myspace. com/ parallelworldsmusic > > www. myspace. com/ interconnectedmusic > > www. myspace. com/ memorygeist > > www. DiN. org. uk > > www. musicamaximamagnetica. com > > www. vu-us. com > > www. shimarecords. co. uk > > --- On Mon, 2/8/10, Greg Cerveny <greg.cerveny@gmail.com<greg.cerveny%40gmail.com>> > wrote: > > From: Greg Cerveny <greg.cerveny@gmail.com <greg.cerveny%40gmail.com>> > Subject: [Doepfer_a100] too many volts on the a132-3? > To: "doepfer_a100" <Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com> > > > Date: Monday, February 8, 2010, 7:38 PM > > > > > Hello all, > > I had my orb sequencer gating @ + 12v into an a142 into an a132-3. > > Now the top vca is not responding consistently to cv signals. The > > gain works fine. The bottom vca works fine. I see the 132-2 accepts > > -8 to +8. Did I put too much voltage into it? > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
good. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com www. shimarecords. co. uk --- On Mon, 2/8/10, Greg Cerveny <greg.cerveny@gmail.com> wrote:
> From: Greg Cerveny <greg.cerveny@gmail.com> > Subject: Re: [Doepfer_a100] too many volts on the a132-3? > To: Doepfer_a100@yahoogroups.com > Date: Monday, February 8, 2010, 9:01 PM > The orb defaults to a 12v trigger. I > need see if I can adjust it. > > Oy... I'm an idiot. When trying out other envelopes, > I realized that it was > the cv attenuator that was the problem. I gave it 100 > rotates and now it's > working. > > On Mon, Feb 8, 2010 at 10:55 AM, Bakis Sirros <synth_freak_2000@yahoo.com>wrote: > > > > > > > or, maybe, you sent too many volts into the trigger > input of the 142... and > > the decay envelope has a problem now...? > > > > does the top vca of the 132-3 work fine with other cv > sources, apart from > > the 142? > > > > the 132-3 vca's accept up to +/- 8 volts without > distortion, in the audio > > input, that does not mean that if the audio signal is > higher the vca's will > > be destroyed.... > > > > btw, why would you have your ORB send a +12 volts > gate, anyway? > > are you triggering Roland envelopes from it, as well? > > > > Bakis Sirros - Parallel Worlds / Interconnected / > Memory Geist > > > > [Doepfer_a100] group owner > > > > www. parallel - worlds - music. com > > > > www. myspace. com/ parallelworldsmusic > > > > www. myspace. com/ interconnectedmusic > > > > www. myspace. com/ memorygeist > > > > www. DiN. org. uk > > > > www. musicamaximamagnetica. com > > > > www. vu-us. com > > > > www. shimarecords. co. uk > > > > --- On Mon, 2/8/10, Greg Cerveny <greg.cerveny@gmail.com<greg.cerveny%40gmail.com>> > > wrote: > > > > From: Greg Cerveny <greg.cerveny@gmail.com > <greg.cerveny%40gmail.com>> > > Subject: [Doepfer_a100] too many volts on the a132-3? > > To: "doepfer_a100" <Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com> > > > > > Date: Monday, February 8, 2010, 7:38 PM > > > > > > > > > > Hello all, > > > > I had my orb sequencer gating @ + 12v into an a142 > into an a132-3. > > > > Now the top vca is not responding consistently to cv > signals. The > > > > gain works fine. The bottom vca works fine. I see the > 132-2 accepts > > > > -8 to +8. Did I put too much voltage into it? > > > > [Non-text portions of this message have been removed] > > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Yahoo! Groups Links > > > Doepfer_a100-fullfeatured@yahoogroups.com > > >
p.s. thanks for the help in working it out! :) On Mon, Feb 8, 2010 at 12:52 PM, Bakis Sirros <synth_freak_2000@yahoo.com>wrote: > > > good. > > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > [Doepfer_a100] group owner > www. parallel - worlds - music. com > www. myspace. com/ parallelworldsmusic > www. myspace. com/ interconnectedmusic > www. myspace. com/ memorygeist > www. DiN. org. uk > www. musicamaximamagnetica. com > www. vu-us. com > www. shimarecords. co. uk > > --- On Mon, 2/8/10, Greg Cerveny <greg.cerveny@gmail.com<greg.cerveny%40gmail.com>> > wrote: > > > From: Greg Cerveny <greg.cerveny@gmail.com <greg.cerveny%40gmail.com>> > > Subject: Re: [Doepfer_a100] too many volts on the a132-3? > > To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > > Date: Monday, February 8, 2010, 9:01 PM > > > The orb defaults to a 12v trigger. I > > need see if I can adjust it. > > > > Oy... I'm an idiot. When trying out other envelopes, > > I realized that it was > > the cv attenuator that was the problem. I gave it 100 > > rotates and now it's > > working. > > > > On Mon, Feb 8, 2010 at 10:55 AM, Bakis Sirros < > synth_freak_2000@yahoo.com <synth_freak_2000%40yahoo.com>>wrote: > > > > > > > > > > > or, maybe, you sent too many volts into the trigger > > input of the 142... and > > > the decay envelope has a problem now...? > > > > > > does the top vca of the 132-3 work fine with other cv > > sources, apart from > > > the 142? > > > > > > the 132-3 vca's accept up to +/- 8 volts without > > distortion, in the audio > > > input, that does not mean that if the audio signal is > > higher the vca's will > > > be destroyed.... > > > > > > btw, why would you have your ORB send a +12 volts > > gate, anyway? > > > are you triggering Roland envelopes from it, as well? > > > > > > Bakis Sirros - Parallel Worlds / Interconnected / > > Memory Geist > > > > > > [Doepfer_a100] group owner > > > > > > www. parallel - worlds - music. com > > > > > > www. myspace. com/ parallelworldsmusic > > > > > > www. myspace. com/ interconnectedmusic > > > > > > www. myspace. com/ memorygeist > > > > > > www. DiN. org. uk > > > > > > www. musicamaximamagnetica. com > > > > > > www. vu-us. com > > > > > > www. shimarecords. co. uk > > > > > > --- On Mon, 2/8/10, Greg Cerveny <greg.cerveny@gmail.com<greg.cerveny%40gmail.com> > <greg.cerveny%40gmail.com>> > > > > wrote: > > > > > > From: Greg Cerveny <greg.cerveny@gmail.com <greg.cerveny%40gmail.com> > > <greg.cerveny%40gmail.com>> > > > > Subject: [Doepfer_a100] too many volts on the a132-3? > > > To: "doepfer_a100" <Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com> > <Doepfer_a100%40yahoogroups.com> > > > > > > > > Date: Monday, February 8, 2010, 7:38 PM > > > > > > > > > > > > > > > Hello all, > > > > > > I had my orb sequencer gating @ + 12v into an a142 > > into an a132-3. > > > > > > Now the top vca is not responding consistently to cv > > signals. The > > > > > > gain works fine. The bottom vca works fine. I see the > > 132-2 accepts > > > > > > -8 to +8. Did I put too much voltage into it? > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > Doepfer_a100-fullfeatured@yahoogroups.com<Doepfer_a100-fullfeatured%40yahoogroups.com> > > > > > > > > > [Non-text portions of this message have been removed]
