Creating rythmical gate sequences using A-160 & A-161
2010-03-17 by peter.erikson
Hi! What i am trying to do is to create a rythmical gate sequence using the gate outputs from the A-160 and A-161 and i am wondering if i am using the right aproach. What i do is that i connect 3 of the gate outputs from the A-160 and and the A-161 to a multipple and then connect the 4:th multipple connector to the gate input on an anvelope generator. I have noticed that when i do this the leds on all connectors (on the A-160 & A-161) that are connected to the multiple light up when any of them is trigged. What i am wondering is if it is correct to use a multipple to "mix" the gate signals from the A-160 & A-161 like this? Or should i be using some other module to do this? I just recently bought my A-100 system so i am quite new to this. Thanks! //Peter
