Doepfer
183-3 mod?
183-3 mod?
2010-04-14 by cera1210
wondering if it'd be possible to swap out a resistor or something
on the 183-3 to change the range from 1-4x loudness to 1-8x, 16 etc?
i am trying to use it to raise a line level signal
from my audio interface output (edirol fa-101)
to a usable level within my a-100 system
the 183-3 is definitely helping but it could use just a little more of a boost.
let me know if anyone has any ideas...
cheers,
mark
AW: [Doepfer_a100] 183-3 mod?
2010-04-14 by yahoo@doepfer.de
> more of a boost. let me know if anyone has any ideas...
> cheers,
> mark
The resistors R3 (10k) and R4 (3k3) define the max. amplifications in the
left (R3) and right (R4) position of the range switch. Lowering the values
of these resistors (or simply soldering resistors in parallel) causes higher
amplifications. R3 is located left from the level control (top view to the
front panel), R4 left from the upper In socket.
The formula for the amplification is 1 + 10k/Rx. The non-inverting amplifier
circuit is used (see A-100 DIY page for details). In this circuit R1 is 10k
and R2 can be switched to 10k or 3k3.
Best wishes
Dieter Doepfer
Re: 183-3 mod?
2010-04-15 by cera1210
hi dieter,
this is perfect!
thanks for the help :)
cheers,
mark
> Best wishes
> Dieter Doepfer
