Has the A-190 midi to Cv outputs Hz/v? or do you know any other module that can?
2010-04-16 by ricardo
Hi I have some metasonix vco's and A100 g6 with doepfer and other 3u modules. I need Hz/v CV for those vco's and I'm looking for something that can convert cv . I know the korg ms-2 but it's impossible to find . In the other hand there are midi to cv converters like kenton with hz/v output but I want something that transforms cv from cv if possible and is 3u. Does anyone know about something like that? Thanks ric
2010-04-16 by Bakis Sirros
elby designs was going to make a LIN to LOG (and vice versa) converter euro module.... anyone knows anything about this module? Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Fri, 4/16/10, ricardo <rrkrdo@yahoo.co.uk> wrote:
Subject: [Doepfer_a100] Has the A-190 midi to Cv outputs Hz/v? or do you know any other module that can?
Date: Friday, April 16, 2010, 11:34 AM
Hi
Thanks
ric
[Non-text portions of this message have been removed]2010-04-18 by phono 1337
the a190-1 will do hz, here's the relevant info from the manual CV CHAR. This parameter sets the voltage control characteri- stics of the pitch CV output from the A-190, so that it�s possible to drive both common types of analog synth - older Korgs, Yamahas, etc., which have a linear re- sponse (Hz / V), and Rolands, ARPs, Moogs, etc., which have a logarithmic response (1V / octave). H For use just with the A-100, the V / octave response is all that is needed. The Hz / V option is provided purely for connecting to external synths which use that standard. M M M M V / Octave : PROG CHANGE 3 Hz / V : PROG CHANGE 4 Paul On 16 April 2010 09:06, Bakis Sirros <synth_freak_2000@yahoo.com> wrote: > > > elby designs was going to make a LIN to LOG (and vice versa) converter euro > module.... > > anyone knows anything about this module? > > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist > > [Doepfer_a100] group owner > > www. parallel - worlds - music. com > > www. myspace. com/ parallelworldsmusic > > www. myspace. com/ interconnectedmusic > > www. myspace. com/ memorygeist > > www. DiN. org. uk > > www. musicamaximamagnetica. com > > www. vu-us. com > > --- On Fri, 4/16/10, ricardo <rrkrdo@yahoo.co.uk <rrkrdo%40yahoo.co.uk>> > wrote: > > From: ricardo <rrkrdo@yahoo.co.uk <rrkrdo%40yahoo.co.uk>> > Subject: [Doepfer_a100] Has the A-190 midi to Cv outputs Hz/v? or do you > know any other module that can? > To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > Date: Friday, April 16, 2010, 11:34 AM > > > > > Hi > > I have some metasonix vco's and A100 g6 with doepfer and other 3u modules. > I need Hz/v CV for those vco's and I'm looking for something that can > convert cv . I know the korg ms-2 but it's impossible to find . In the other > hand there are midi to cv converters like kenton with hz/v output but I want > something that transforms cv from cv if possible and is 3u. Does anyone know > about something like that? > > Thanks > > ric > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2010-04-19 by yahoo@doepfer.de
> the a190-1 will do hz, > > here's the relevant info from the manual > > CV CHAR. > This parameter sets the voltage control characteri- > stics of the pitch CV output from the A-190, so that its > possible to drive both common types of analog synth - > older Korgs, Yamahas, etc., which have a linear re- > sponse (Hz / V), and Rolands, ARPs, Moogs, etc., > which have a logarithmic response (1V / octave). > H For use just with the A-100, the V / octave > response is all that is needed. The Hz / V > option is provided purely for connecting to > external synths which use that standard. > M M M M V / Octave : PROG CHANGE 3 > Hz / V : PROG CHANGE 4 > > Paul Just a remark: this feature is not mentioned in the product description of the A-190-1 because we had no chance to test the Hz/V mode. As far as I remember Hz/V we discussed if we should remove the Hz/V mode from the A-190-1. But then we decided to leave it as kind of a "free gift" or hidden, untested feature ! It was a bit tricky because it's not a linear scale as in the V/octave mode. If one changes the scale in the Hz/V mode the complete log scale is affected. That's why the Hz/V mode is not a feature that is included in the product description. Best wishes Dieter Doepfer
2010-04-20 by ricardo
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > the a190-1 will do hz, > > > > here's the relevant info from the manual > > > > CV CHAR. > > This parameter sets the voltage control characteri- > > stics of the pitch CV output from the A-190, so that it's > > possible to drive both common types of analog synth - > > older Korgs, Yamahas, etc., which have a linear re- > > sponse (Hz / V), and Rolands, ARPs, Moogs, etc., > > which have a logarithmic response (1V / octave). > > H For use just with the A-100, the V / octave > > response is all that is needed. The Hz / V > > option is provided purely for connecting to > > external synths which use that standard. > > M M M M V / Octave : PROG CHANGE 3 > > Hz / V : PROG CHANGE 4 > > > > Paul > > Just a remark: this feature is not mentioned in the product description of > the A-190-1 because we had no chance to test the Hz/V mode. As far as I > remember Hz/V we discussed if we should remove the Hz/V mode from the > A-190-1. But then we decided to leave it as kind of a "free gift" or hidden, > untested feature ! It was a bit tricky because it's not a linear scale as in > the V/octave mode. If one changes the scale in the Hz/V mode the complete > log scale is affected. That's why the Hz/V mode is not a feature that is > included in the product description. > > Best wishes > Dieter Doepfer > That is great news! I just ordered my A-190-1 from EMIS . Thanks a lot for the info. I'll be writing again with more questions like that. Thanks again Ric
