> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Simon
> Gesendet: Dienstag, 20. April 2010 11:47
> Betreff: [Doepfer_a100] Re: Can I trigger the CV on the Doepfer A-150 ?
> Well, the thing is that my Doepfer 5V adaptor broke, so I haven't
> tested the MT9 yet, but I have ordered one that will arrive today.
> MT9:
> "Introduction
> The MT9 is a MIDI to triggering module. It allows triggering of a
> range of analogue devices; drum voice modules, envelope modules,
> analogue sequencers, analogue drum machines, and anything else
> with a gate, trigger or clock input.
> It has 9 separate 5v trigger outputs, so 9 devices can be
> independently triggered via separate MIDI keys. There is also an
> ACCent output.
> ACCENT
> The ACC is an on (5v) / off (0v) output. When velocity of over 80
> is received for any of the 9 triggers, then the Accent will go
> high (5v). Lower than 80 the output will go low (0v). Use this
> output to control other analogue modules.
> Note: it is not directly compatible with the drum module ACC
> inputs. The naming of this socket is perhaps misleading if you
> use our drum modules. The drum modules require a different type
> of accent signal; 12v on, about 5v off. We may (or may not) make
> an 'Accent' add-on module.
> Outputs:
9 independent trigger outs + Accent on/off
MIDI Thru
> Power supply:
+5V, GND Doepfer A100 type power sockets"
> I believe it's a short trigger signals and this would be perfect
> for switching the A-150, if the CV input was a trigger input...
> Thanks, I really appreciate your help.
> Best wishes
> Simon
> --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > Does your MT9 output 9 gates (i.e. the output remains high until the
> > corresponding note off message is transmitted) or only short
> trigger signals
> > ? If gate signals are available the A-150 should do the job.
> Otherwise A-151
> > can be used (in this case the state changes with each trigger pulse).
> > Best wishes
> > Dieter Doepfer
> > > Gesendet: Dienstag, 20. April 2010 10:48
> Doepfer A-150 ?
> > > I use the A-150 as a gate; audio/CV signal IN1, nothing in IN2,
> > > audio out I/O.
> > > I know that the A-151 is capable of this - I have one myself -
> > > but since the A-150 is made of two identical modules, this would
> > > save me a lot of rack space.
> > > The thing is that I would need six A-150 instead of twelve A-150!
> > > The MT9 midi-trig from Analogue Solutions can switch between nine
> > > trigger signals and what is very important, I can make Max/Msp
> > > switch between the nine triggers in any order I like.
> > > So with two MT9 and six A-150 it would be possible to have plenty
> > > of "gates" incorporated in my modular system and only use 44 HP
> > > of rack space.
> > > Isn't this the best solution, if the A-150 can be triggered, for
> > > my system?
> > > Best wishes
> > > Simon
> > > --- In Doepfer_a100@yahoogroups.com, <yahoo@> wrote:
> > > > > I have tested the Doepfer A- 152, but it doesn't seem to suit
> > > my needs.
> > > > > Is it possible to change the CV inputs of the A-150 to a
> > > trigger input?
> > > > > Or maybe it's too expensive?
> > > > > Thanks
> > > > > Simon
> > > > From what you asked for several A-152 should be right solution.
> > > > Anyway: What should the A-150 trigger input do:
> > > > a) toggle between the two inputs ?
> > > > b) switch to input #2 as long the trigger signal is high ?
> > > > Version a) is already available with the A-150. If you want
> to toggle
> > > > between 2 inputs the A-151 could be used (limited to 2 steps by
> > > means of the
> > > > switch).
> > > > Best wishes
> > > > Dieter Doepfer
> > > Yahoo! Groups Links
