> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von lre
> Gesendet: Sonntag, 3. April 2011 19:01
> Betreff: [Doepfer_a100] Re: 177-2 foot controller issues
> Hi --
> I'm hoping to pull my 177-2 back off the shelf again, and
> wondering if Dieter or anyone else using this module might be
> able to help out with the questions below. Thanks in advance!
> Ernst
> --- In Doepfer_a100@yahoogroups.com, "E_Karel" <ekarel@...> wrote:
> > Hello Dieter,
> > Thanks for your earlier responses. I dropped this thread and
> have been using my old 177, but I'd like to use the 177-2 if
> possible, so here are some more comments/questions:
> > --- In Doepfer_a100@yahoogroups.com, <yahoo@> wrote:
> > > I suppose that it has to do with the bouncing of the
> contacts of your foot
> > > pedal (i.e. that releasing the pedal is not a clean on/off
> transition but a
> > > sequence of on/off/on/off transitions until the final state
> is reached). If
> > > the A-177-2 is used to switch a signal (e.g. by means of the
> A-150) this
> > > causes no problems but if the foot switch is used as a
> trigger (e.g. S&H or
> > > clock circuits) this may lead to a problem. Especially older
> contacts may
> > > generate a lot of bouncing.
> > You're right about the 150, but when I use it with the 151 it
> goes crazy, and is basically unusable. Each trigger causes a
> flashing of lights and moves an unpredictable number of stages in
> the sequence.
> > > Maybe adding a capacitor to the inputs will
> > > solve the problem. They would work like low pass filters that
> filter the
> > > bouncing pulses. One has to try it out as it depends upon the bouncing
> > > behaviour of the contacts. I'd start with ~ 100nF connected
> between GND and
> > > the foot switch inputs.
> > Sorry, but I'm ignorant about these things -- how would I do
> this exactly?
> > > > And isn't the behavior I mentioned in my second message quite
> > > > strange? I'll quote it again here:
> > > > "If I have output #1 from the 177-2 double footswitch patched to
> > > > the 165 trigger modifier input, and nothing patched from output
> > > > #2, only pressing footswitch #1 shows up on the LEDs on the 165.
> > > > Footswitch #2 appears to do nothing. So far so good. However, if
> > > > I patch from the mini-mult of the 165 to the trigger input of the
> > > > S&H 148, then even though only #1 registers on the 165, BOTH
> > > > footswitches #1 and #2 pass gate on to the S&H."
> > > That's indeed strange. I'll try to copy the behaviour in our
> demo system. It
> > > probably has to do with glitches and bouncing and the different input
> > > behaviour of A-165 and A-148 in case of glitches at the input.
> > Did you happen to get a chance to look at this?
> > Thanks again!
> > Ernst
