Re: Advice on the usefulness of an A-115 Audio Divider?
2011-01-28 by zaum
You ideally run one oscillator into it. Whatever the frequency is that goes in you get a square wave that's half, a quarter, an 8th and a 16th of the frequency coming out with adjustable levels. In musical terms you get 1, 2, 3 and 4 octaves under separately adjustable. So it basically synthesizes new bass frequencies you can balance the levels of. Historically you saw the /2 on a number of vintage synths being called a sub-oscillator, mostly synths with only a single oscillator. It gives you a bigger, deeper sound than a single oscillator -- though is a lot less flexible than adding an expensive second VCO. With a real VCO you can detune and modulate it to potentially sound even bigger and use any wave it can produce rather than a square. Then again with the A-115 you'd potentially need 4 VCOs to do what it does in a limited way. If you give it an ambiguous frequency, for example a mix of sounds or a percussion sound you'll get something odd but potentially usable since it's going to be a lower frequency made up of square waves.
