Doepfer
any way to control a 152 with a 154?
2011-02-06 by dancemachine
i love the control of the 154, specifically the VC last step, but
don't really need the 155.  I'd just like to control the 152
addressable switch with it.  I can get a lot of good stuff when using
the CV in of the 152, along with pre-processing, but when using clock
in, I can't seem to figure out a way to do VC last step.  the only
idea I can think of is actually to get another 152, which i find
awesomely hilarious.  finally, the modes of the 154 would be sweet.
I've also thought that maybe I could clone the section of the 155 that
has the 8 jacks at the bottom including the output from that row.  the
155 seems fairly modular in itself looking at the back
http://www.doepfer.de/A100_pictures/doepfer_a155.jpg
as does the 152
http://www.doepfer.de/A100_pictures/doepfer_a152.jpg
anyway i guess my question is, does anyone know about this bus between
the 155 and 154? and also internally in the 155 and 152?  I don't have
the doepfer service docs (yet?)
thanks.  these modules seem like they are designed simply enough that
this kind of stuff might be possible...
AW: [Doepfer_a100] any way to control a 152 with a 154?
2011-02-07 by yahoo@doepfer.de
> as does the 152
If you are experienced with electronics thats possible. You have to
interrupt the internal A-152 addressing (three address signals A0, A1, A2)
and connect the three address signals to the corresponing pins of the A-154.
Some soldering is required as you cannot use the high voltage address
signals (0/+12V) of the A-154 which are available at the socket that is use
to establish the connection to the A-155. Instead of this the internal low
voltage address signals (0/+5V) of the A-154 have to be used.
Best wishes
Dieter Doepfer
Re: [Doepfer_a100] any way to control a 152 with a 154?
2011-03-26 by dancemachine
great, thanks for the info.  are there service docs available or anything so
that I may complete this modification?  I have a 154 and 152 here waiting
for me to hook them together :)
> > as does the 152
> A-154.
> Best wishes
> Dieter Doepfer
