Doepfer
Highpass modification for A-127 version 3
2011-03-27 by Florian Anwander
If you own an A-127, then you that it can be changed from band pass to
low pass with internal jumpers.
Now: If you have an A-127 Version 3 (the version is written on the
pcbs), then it is also possible to get a high pass signal too. You
simply have to feed pin 14 of IC1 to the center pin of the selection
jumper; you can pick this signal at the right side of R15, which is the
resistor direct aside the unused trimmer P8. One cable nothing else!
Btw: the A127 is a hidden gem as it provides in fact three SEM filters!
Florian
Re: [Doepfer_a100] Highpass modification for A-127 version 3
2011-03-27 by ikke
How about a switch Dieter
2011/3/27 Florian Anwander <fanwander@mnet-online.de>
> Hi,
> Florian
Hi Ikke
The problem is, that you would need a real three position rotary switch.
Which eats space on the frontpanel and is expensive.
But already three jumpers would be great.
Florian
Re: AW: [Doepfer_a100] Highpass modification for A-127 version 3
2011-03-28 by Denis Gökdag
Hmmm, I guess you could maybe wire up an A-138-e quad three-way crossfader module to get SEM-style crossfading between filter modes for all three A-127 filters. The fourth crossfader could probably be modified to sum all three filters with a level control (or be left as-is to do a three-way crossfade between the three filters).
This would probably make most sense if you also add separate inputs for the filters.
Ahh, a new project for when I actually have some spare time ;-)
Best,
Denis
> No problem. We did this several times but it causes additional charges
> because of the required working time and parts.
> Best whishes
> Dieter Doepfer
Re: Highpass modification for A-127 version 3
2011-03-28 by NetPierre
Cool, thanks for the tip. It already was one of my favorite filter modules.
I made an expansion module for the low-pass/bandpass modification
info here :
http://patchpierre.blogspot.com/search/label/A-127
I guess i have to expand my expansion module now...
btw... feel free to check out the rest of my blog too ;-)
Find it at http://patchpierre.blogspot.com
Greetings,
            Pierre / NetPierre / PatchPierre
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hi,
> Florian
