Doepfer
A-110 fine tune range
2011-02-13 by Matt
How easy is it to extend the range of the fine tune control on the
A-110 (the A-110 page on the Doepfer website says only "can be
modified for a wider range").
As standard it's set to the extremely limited range of +/- a semitone,
which is useful for precise tuning of several VCOs to the same pitch
but quite useless if you want to tune to a different interval.
Also the Range controls on my two A-110s have several more positions
than the five marked on the panel - is that normal on the current
model?
Matt
Re: [Doepfer_a100] A-110 fine tune range
2011-02-14 by Florian Anwander
Hi Matt
You have to reduce the value of the resistor R5. You simply may solder a
new resistor in parallel to the existing resistor. The smaller this
resistor, the wider is the range of the potentiometer.
see also http://www.doepfer.de/a110_tec.htm
Florian
