AW: [Doepfer_a100] Re: Can't trigger A-140 from A-190-2
2011-02-17 by York Luethje
Doepfer is his last name. Polite people will address him as Mr / Herr Doepfer or with his first name Dieter if you're Anglo-Saxon / Scandinavian. Just calling him 'Doepfer' is seriously rude. _____ Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] Im Auftrag von Sidney Gesendet: Donnerstag, 17. Februar 2011 01:10 An: Doepfer_a100@yahoogroups.com Betreff: [Doepfer_a100] Re: Can't trigger A-140 from A-190-2 Doepfer, I successfully replaced the A-190-2 defective Q1 with a new BC547B transistor. Now the gate is working. But I think that the CV V/V is not working. I didn't test it before. Is there a way to fix it? Thank you, Sidney --- In Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> , <yahoo@...> wrote: > > > I think I had plugged the A190-2 the wrong way the first time I > > plugged it into the power bus board, and might damaged the unit. > > It seemed to be working fine, as it was receiving midi messages > > and activating the A110 both from the CV1 and pitch bend from > > CV2. But the gate output problem and out of tune scale indicated > > there is something wrong really. Maybe I will be necessary to buy > > a new one. > > > > Thank you for the kind attention. > > > > Sidney. > > If the A-190-2 was plugged in the wrong way the gate output is fried. In > this case the collector of the npn gate output transistor is connected > to -12V which destroys the transistor. This explains why the gate output > does not work anymore. It is difficult to say if other sections of the > module are defective too. You may try to replace the transistor (Q1, BC547C) > to see if this is the only defective part. Or you send in the module for > repair to the dealer where you purchased the device. > > Best wishes > Dieter Doepfer > [Non-text portions of this message have been removed]
