Doepfer
Dark Time vs Oberkorn M3
2011-04-17 by malcolm
Hello All,
I'm new to hardware sequencing and am trying to decide between buying the Doepfer Dark Time and the Oberkorn M3 a my first hardware sequencer!
What I'm looking for...
 - sequence midi and cv enabled hardware synths and maybe soft synths
 - easy integration with Logic as the 'master' clock
 - maximum tweakability and experimental potential
 - relatively east to understand - although I'm not afraid of a learning curve
I do not currently own a CV-MIDI converter
Any advice or opinions are much appreciated!
Best,
Malcolm, NYC
Re: [Doepfer_a100] Dark Time vs Oberkorn M3
2011-04-17 by David Bulog
Dark time is a better design
On 17/04/2011, at 3:40 PM, malcolm wrote:
> Hello All,
> Best,
> Malcolm, NYC
2011-04-17 by watson
if you have the money look into the sequentix cirklon. it has midi,cv,din
and can be used as a midi/cv converter.
> > Hello All,
> curve
> > Best,
> > Malcolm, NYC
AW: [Doepfer_a100] Dark Time vs Oberkorn M3
2011-04-17 by York Luethje
Did you by any chance mean the Oberkorn v3? If so, the Oberkorn and the Dark
Time are not really comparable. A better match would be the Doepfer MAQ
16/3.
There is a smaller sequencer from Analogue Solutions called the Station Q
that's closer to the DT. Since it is only 8 steps and lacks MIDI this will
be not as good a fit for your needs as the Dark Time.
The DT should be easy to integrate with Logic. It is also pretty
straightforward: Gate and CV output, either 2x8 or 1x16 steps, forward,
backward and random.
As for experimental potential I don't know. Define experimental. I would
think that the Oberkorn or the MAQ are better bets here (or the A 155 / 154
combo if you plan on going modular).
  _____
Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] Im
Auftrag von malcolm
Gesendet: Samstag, 16. April 2011 23:41
An: Doepfer_a100@yahoogroups.com
Betreff: [Doepfer_a100] Dark Time vs Oberkorn M3
Hello All,
curve
Best,
Malcolm, NYC
Re: Dark Time vs Oberkorn M3
2013-06-27 by pete_dako
Dark Time will do MIDI ( & CVs) out/in
Oberkorn M3 does not send out MIDI just CVs - though it responds to a MIDI clock in
both are wonderful and uniquely different — ditto MAQ 16/3
I suggest buy all three! :D
> 16/3.
>   _____
> Auftrag von malcolm
> Hello All,
> curve
> Best,
> Malcolm, NYC
