Doepfer
New poll for Doepfer_a100
2011-06-09 by Doepfer_a100@yahoogroups.com
Enter your vote today!  A new poll has been created for the
Doepfer_a100 group:
Should Doepfer release new envelope generator modules?
Like ADDSR, AHDSR... with slope parameter for each phase.
ADDSR= Attack Decay1 Decay 2 Sustain Release
AHDSR= Attack Hold Decay Sustain Release
  o No! The envelope generator modules already available are ok.
  o Yes! ADDSR, AHDSR and slope parameter for each phase.
  o Yes! but ADDSR it's enough...
  o Yes! but ADDSR with slope parameter for each phase it's enough...
  o Yes! but AHDSR it's enough...
  o Yes! but AHDSR with slope parameter for each phase it's enough...
  o Yes! ADDSR, AHDSR but no slope parameter.
To vote, please visit the following web page:
http://groups.yahoo.com/group/Doepfer_a100/surveys?id=13087131
Note: Please do not reply to this message. Poll votes are
not collected via email. To vote, you must go to the Yahoo! Groups
web site listed above.
Thanks!
Re: [Doepfer_a100] New poll for Doepfer_a100
2011-06-09 by dancemachine
I think I'd rather see a VC A(S)R module, or something with voltage
control.  does "slope parameter" mean shape control btwn log/lin/exp?
because that is definitely welcome, but I think that simpler VC envelopes
would prove more desirable to the market than complicated non-VC envelopes
is this an option on the poll? :)
> Doepfer_a100 group:
> Thanks!
Re: New poll for Doepfer_a100
2011-06-10 by mfretton
This would be really useful - I'm frequently frustrated by the envelope of a standard ADSR as it can't adequately replicate those  of natural sounds. The ADDSR would be particularly good to have.
On another note, it would be great if they could be either 4HP (which seems unlikely) or 6HP, as space is always an issue.
> Doepfer_a100 group:
> Thanks!
RE: [Doepfer_a100] New poll for Doepfer_a100
2011-06-10 by david.salter@thomsonreuters.com
I'm very much in agreement here, VC of parameters make a much more
versatile module (any module) and I'm a big fan of AD or AR envelopes.
David
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of dancemachine
Sent: 09 June 2011 21:18
Subject: Re: [Doepfer_a100] New poll for Doepfer_a100
envelopes would prove more desirable to the market than complicated
non-VC envelopes
> Doepfer_a100 group:
> ADDSR= Attack Decay1 Decay 2 Sustain Release AHDSR= Attack Hold Decay
> Sustain Release
> Note: Please do not reply to this message. Poll votes are not
> collected via email. To vote, you must go to the Yahoo! Groups web
> site listed above.
> Thanks!
Yahoo! Groups Links
2011-06-10 by john m
I really like multi-stage envelopes (cz1000, nord modular, etc).
8 stages and you select which stage is the sustain. Added cv control would be immense.
> Doepfer_a100 group:
> Thanks!
2011-06-10 by Florian Anwander
Hello John and David,
Am 10.06.2011 12:54, schrieb john m:
 > would be immense.
If there should be a new envelope module, then it should be not reduced
to certain functions like attack or decay or what ever. So I subscribe
to Johns request for a multistage envelope.
There are several stages, basically with an slew time and a destination
voltage. The destination voltage of the last stage is the note-off
voltage. The destination voltages can have values between +10V and -10V.
StageX-Level: this is the voltage to where this stage changes to. The
last stage will have an additional switch to set this level to 0V
(=normal envelope).
StageX-Rate: this is the rate at which the StageX-Level will be reached.
There should be a switch for mid/fast/slow per stage.
StageX-LoopStart: this is an on/off switch. It determines the start of
the envelope loop
StageX-LoopEnd: this is an on/off switch. It determines the end of the
envelope loop
If StageX-LoopStart and StageX-LoopEnd are activated at the same stage,
then you have an normal Sustain.
If StageX-LoopStart and StageX-LoopEnd are activated at the different
stages, the Sustain phase will circulate through the corresponding stages.
The big advantage of this kind of envelope: you can achieve negative and
positive modulations within the same envelope, and the amount still will
be controlled by a simple env amount potentiometer.
Am 10.06.2011 09:02, schrieb david.salter@thomsonreuters.com:
Me too. Mostly I am a big fan of the envelopes of the moog rogue. It has
Attack and Decay as parameters and can be switched between AD and ASR. I
made recently rougly a pcb in eagle for it:
http://fa.utfs.org/diy/a100/rogue_envelope/index.html
Florian
2011-06-10 by Martin Fay
And me. While there are various alternatives in euroland as a whole
I'm sure Dieter would be able to offer a lower price point in Europe
at least.
Martin
> David
> non-VC envelopes
> > Doepfer_a100 group:
> Decay
> > Sustain Release
> > site listed above.
> > Thanks!
2011-06-11 by Giorgio
couldn't a a-155 be patched up for these kind of functions?  maybe I'm wrong but I thought of it on another reply for a arbitrary envelope, and this sounds just like an a-155 with supporting modules.  maybe I'm wrong
On Jun 10, 2011, at 8:51 AM, Florian Anwander <fanwander@mnet-online.de> wrote:
> > would be immense.
> (=normal envelope).
> the envelope loop
> envelope loop
> Florian
2011-06-12 by Florian Anwander
Hello
perhaps it is possible. But it would be very difficult. It still would
require additional modules: A VC slewlimiter, which has to be set very
exactly. A154 as voltage controlled clock for the envelope times. An
offset for the output voltage, a trigger converter for the
gate-to-start/stop conversion....
Florian
2011-06-13 by david.salter@thomsonreuters.com
Hi Florian,
I understand the benefits of the multistage envelope and have DIY'd
something similar which is very useful.
It wasn't my intention to disregard the poll (I had already voted Yes) I
was just trying to emphasis that for most uses ADSR has more stages than
people really use and a simpler envelope would be most useful, in fact I
believe there was discussion for such a module in the past.
I too am a fan of the Rogue envelope, the nearest I have to that is the
BugBrand EG which has an AD/ASR switch ;)
Thank you for the explanation as well as it's always good to get a
fuller view of a proposed module.
Rgds
David
David Salter
Senior Consultant
Solutions Services EMEA North
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
thomsonreuters.com <http://thomsonreuters.com/>
On Behalf Of Florian Anwander
Sent: 10 June 2011 13:51
> would be immense.
(=normal envelope).
the envelope loop
envelope loop
stages.
<mailto:david.salter%40thomsonreuters.com> :
Florian
2011-06-13 by john m
Really liking the sound of that Florian!
>  > would be immense.
> (=normal envelope).
> the envelope loop
> envelope loop
> Am 10.06.2011 09:02, schrieb david.salter@...:
> Florian
