I tend to disagree. having tried both methods of controlling the MS-20 over the years, using the native Hz/V and S-trig inputs has produced far more musical results in my experience, and has left the modulation paths open for pitch and timbre controls. I have considered building an MS-02 clone, knowing that many MS-20 owners would appreciate owning such a device to avoid the kludge of the workaround used by some (as mentioned below). it does work in a pinch though.
On Jul 12, 2011, at 4:03 AM, Florian Anwander <fanwander@mnet-online.de> wrote:
> Hello,
> A V/Oct --> V/Hz converter is not really necessary, as the MS20 provides
> V/Oct inputs (VCO/VCF CV-In). For Gate->Korg Trigger conversion you may
> use a A150 (VC switch) or a A165 (gate converter): the Korg trigger
> input accepts switched triggers (close to ground) and/or inverted Gates.
> Florian
> Stuart wrote:
> > The MS-02 was designed as converter between Hz/V and Oct/V synths so they can be
> > used together as if they all talk the same language. I want to investigate if
> > there is enough interest for a module that has the functionality of the Korg
> > MS-02. It makes it possible to integrate Doefer modules with Korg synths and
> > vice versa. You don't need an expansive SQ-10 but could use the A-155 sequencer
> > instead. Etc.
> > ________________________________
> > From: York Luethje<ybl@yahoo.com>
> > To: Doepfer_a100@yahoogroups.com
> > Sent: Mon, July 11, 2011 9:55:14 PM
> > Subject: AW: [Doepfer_a100] New poll for Doepfer_a100
> > Forgive me if I fail to see the point of this. Wasn't the MS-02 designed
> > specifically because the MS series runs on Hz/Oct as opposed to V/Oct? For
> > all other functions of the MS-02 there already exist modules in the Doepfer
> > range as far as I can see. So you want Doepfer to produce a Hz/Oct
> > converter?
> > _____
> > Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> > Gesendet: Montag, 11. Juli 2011 11:35
> > An: Doepfer_a100@yahoogroups.com
> > Betreff: [Doepfer_a100] New poll for Doepfer_a100
> > Enter your vote today! A new poll has been created for the
> > Doepfer_a100 group:
> > In my search for a Korg MS-02 I haven't been successful so far. In building
> > a great A-100 modular synth I was. This got me thinking: It would be great
> > if Doepfer would add a module to the A-100 module list with the
> > functionality of the Korg MS-02. I can imagine more people are interested. I
> > sent the question to Dieter and he suggested to start a poll on this list.
> > So here we go.
> > o I would be interested in a Korg MS-02 like module as long it's cheaper
> > than 100 euro
> > than 150 euro
> > than 200 euro
> > o I'm not interested in such a module
> > To vote, please visit the following web page:
> > http://groups.yahoo.com/group/Doepfer_a100/surveys?id=13091910
> > Note: Please do not reply to this message. Poll votes are
> > not collected via email. To vote, you must go to the Yahoo! Groups
> > web site listed above.
> > Thanks!
> > [Non-text portions of this message have been removed]
> > Yahoo! Groups Links
