Re: extremely dangerous diy-rack construction in the photo section
2011-08-03 by richyho@btopenworld.com
As far as I can see that's carrying 12V from the external 'brick' of a Doepfer DIY kit, not a 240v 'PSU 2'. Not my case, but I have a DIY kit and was considering doing something similar (not XLR though) to allow for disconnection of the power brick. Rich --- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> > Hello! > > I am risking to be called a nitpicker now: > > There is a DIY-rack in the photosection uploaded by acakveld. This case > is constructed in a extremely dangerous way. The XLR-Socket on the right > side in these pictures....: > > http://xa.yimg.com/kq/groups/3183706/sn/483129258/name/first+light.jpg > http://xa.yimg.com/kq/groups/3183706/sn/444387654/name/first+noise.jpg > > ... is used as 230V input. This is something that NEVER NEVER NEVER > should be done. > 1.) The solder connections on the XLR socket are not isolated, e.g. with > heat shrink tube. If you mount a module, in the rack you are not secured > against high voltage. > 2.) XLR-Sockets are not intended for AC voltages in this range (e.g. > Neutrik tells the rated voltage of 50 V AC !!!). > 3.) Imagine an cable with XLR female connector laying around in your > studio, and you do not see the other end. You connect it with a > microphone or any other audiooutput and BANGGGG.... damn, that wasn't > the microphone cable, but the 230V AC for the modular system (if you > still can recognize this - you also might be dead in this moment already!) > > This is nearly the worst kind of doing this. Sorry to say, but I'd like > to suggest, that these pictures have to be removed from the photo > section. Noone should take these as examples. Dieter? > > Florian >
