> Here is a side from you keyboard maual you have to send A MIDI CC 65
> with Max value for the glide to change to on then you could change the
> glide time manually
> jonas
> Wheel Assignment
> It is possible to assign different MIDI controller numbers to the
> Modulation wheel . These parameters are called MIDI
> continuous controllers (MIDI CC) . There are 128 MIDI continuous
> controllers (0-127, counting from and including zero) plus
> an additional 4 proprietary M-Audio controller numbers for a total of
> 132 assignable parameters (counting from and including
> zero to 131) . Numbers beyond 127 are a proprietary method M-Audio
> uses to simplify the transmission of certain, otherwise
> more complicated multi-part MIDI messages . A full list of controller
> values is given at the end of this manual in Appendix
> C . For these controller values to have any effect on the sound, the
> receiving software or device has to be able to read and
> respond to these MIDI controller messages .
> Some examples of useful MIDI CCs are:
> ï¼ 01 Modulation ï¼ 07 Volume ï¼ 10 Pan (balance) ï¼ 05
> Portamento Time
> To assign a MIDI controller message to the Modulation wheel:
> 1 . Press the Edit Mode button .
> 2 . Press the black key above F4 (F#4), representing âWheel
> Assign .â
> 3 . Use the Numerical Data Entry keys G4 â" B5 to enter the number
> of the MIDI controller you want to assign to the
> Modulation wheel .
> 4 . Press the Enter key (C6) .
> If you make an error while entering the numerical data value, you
> can press the CANCEL key (C2) to exit Edit mode
> without changing the MIDI CC assigned to the Modulation wheel .
> As an example, letâs assign MIDI CC number 10 to the Modulation
> wheel. This means the Modulation wheel will
> control Pan (or balance):
> Assign .â
> 3 . Press A4 to enter â1 .â
> 4 . Press G4 to enter â0â so you have entered â10 .â
> 5 . Press C6 for âENTER .â
> To re-assign the Modulation wheel to its default function:
> Assign .â
> 3 . Press the F4 key (Default) . When the Default key is pressed,
> the parameter is reset to its default value, and
> Performance mode resumes .
> | 34
> ProKeys Sono 61 User Guide
> Pedal Assignment
> The Sustain pedal can be assigned to send standard MIDI CCs up to 127
> and extended custom messages from 128 to 131 .
> The default for the Sustain pedal is sending MIDI Controller message
> 64 . Use the G#4 key in Edit mode to change the MIDI
> CC assignment for the Sustain Pedal .
> To assign a MIDI controller message to the Sustain Pedal jack:
> 2 . Press the black key above G4 (G#4), representing âPedal
> Assign .â
> of
> the controller value you want to assign to the Sustain Pedal Jack .
> 4 . Press C6 for âENTER .â
> If you make an error while entering the numerical data value, you can
> press the
> CANCEL key (C2) to exit Edit mode without changing the MIDI CC
> assigned to
> the Sustain Pedal jack .
> To re-assign the Sustain Pedal jack to its default function:
> Assign .â
> the
> parameter is reset to its default value, and Performance mode
> resumes .
> Knob Assignment
> The Voice Volume knob can be assigned to any of 132 controllers
> (0-131) shown
> at the back of this manual in Appendix C .
> To assign a MIDI controller message to the Voice Volume knob:
> 2 . Press the black key above A4 (A#4), representing âKnob
> Assign .â
> of
> the controller value you want to assign to the Voice Volume knob .
> press the
> assigned to
> To re-assign the Voice Volume knob to its default function:
> Assign .â
> the
> resumes .
> NOTE: Optional MIDI parameters assigned to the Voice Volume knob,
> Modulation wheel, or Sustain
> Pedal jack are not stored when the keyboard is turned off. These
> parameters will reset to their
> default values each time the keyboard is powered on.
> TIP: Using the Modulation wheel or
> Voice Volume knob to set the reverb
> or chorus depth on ProKeys Sono
> Changing Reverb Depth
> The Modulation wheel and/or the Voice
> Volume knob can be re-assigned to control the
> depth of the built-in ProKeys Sono reverb. To
> do this:
> 1. Press the Edit Mode button.
> 2. Press either the Wheel Assign (F#4) or
> Knob Assign (A#4) key.
> 3. Press B5 to enter â9.â
> 4. Press A4 to enter â1â so you have
> entered â91.â
> 5. Press C6 for âENTER.â
> This setting can be undone by powering the
> unit off and back on, or by using the Default
> key as described in the next section.
> CC 91 is the standard MIDI controller number
> for reverb depth (see Appendix C).
> Changing Chorus Depth
> depth of the built-in ProKeys Sono chorus. To
> do this:
> 4. Press C5 to enter â3â so you have
> entered â93.â
> CC 93 is the standard MIDI controller number
> for chorus depth (see Appendix C).TIP: Using the Modulation wheel or
> do this:
> entered â91.â
> do this:
> entered â93.â
> | 35
> Restoring Default Assignments
> The Default key is used to selectively reset controller assignments .
> To reset a specific controller assignment, be sure you
> are in Edit mode . Press the key for the parameter you would like to
> reset (Knob Assign, Pedal Assign, or Wheel Assign), and
> then press the Default key (F4) . When the Default key is pressed, the
> mode resumes .
> NOTE: Each time the keyboard is turned off, optional MIDI parameters
> assigned to specific
> hardware controllers will be lost, and the defaults will be restored.
> 16 aug 2011 kl. 09.18 skrev Ton Akveld:
> > Hi Jonas,
> > Thanks for the help.
> > But, as I still don't have the foggiest idea how to send the proper
> > messages in MIDI from my M-Audio ProKeys, I tried to change the
> > portamento manually:
> > Using the Group button I chose the Performance menu, then I used the
> > Menu button to go down to Glide Time, and subsequently pressed Inc
> > to increase the portamento.
> > No increase alas :-)
> > Kind regards,
> > Ton
> > --- In Doepfer_a100@yahoogroups.com, jonas karlsson <jonas.k@>
> > wrote:
> > > Hi Ton
> > > i just tried my A-190 and the glide menu just change the portamento
> > > time but you also have to toggle it on/off and you do that with
> > contro
> > > change messege 65. if you do that it will work
> > > se the manual side 18 glide /portamento on/off, I toggled it on/off
> > > from Logic but if you have a master keyboard you should send a cc65
> > > message with the value over 64.
> > > Jonas
> > > 16 aug 2011 kl. 07.57 skrev Ton Akveld:
> > > > Hi Ernst,
> > > > Read that, but alas also no change...
> > > > I use the A-190-1 by the way.
> > > > Thanks for replying.
> > > > Regards,
> > > > Ton
> > > > --- In Doepfer_a100@yahoogroups.com, achtung_999
> > > > <heinrich.himmelwasser@> wrote:
> > > > > Hee Ton,
> > > > > Page 15 of the manual: http://www.doepfer.de/a100_man/A190_man.pdf
> > > > > If it is the A190-1 you are using that wasn't too clear...
> > > > > Groetjes,
> > > > > Ernst
> > > > > On Mon, Aug 15, 2011 at 7:53 PM, Bakis Sirros
> > > > <synth_freak_2000@>wrote:
> > > > > > hi Ton,
> > > > > > i have never tried to change the portamento time in my A190...
> > > > > > i guess Dieter can help ...?
> > > > > > best regards,
> > > > > > Bakis.
> > > > > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist
> > > > > > [Doepfer_a100] group owner
> > > > > > www. parallel - worlds - music. com
> > > > > > www. facebook. com/ pages/Parallel-Worlds/192093934136476
> > > > > > www. myspace. com/ parallelworldsmusic
> > > > > > www. myspace. com/ interconnectedmusic
> > > > > > www. myspace. com/ memorygeist
> > > > > > www. DiN. org. uk
> > > > > > www. musicamaximamagnetica. com
> > > > > > www. vu-us. com
> > > > > > --- On Mon, 8/15/11, Ton Akveld <aca@> wrote:
> > > > > > From: Ton Akveld <aca@>
> > > > > > Subject: [Doepfer_a100] Re: Newbie question MIDI-CV/SYNC
> > > > interface A-19
> > > > > > To: Doepfer_a100@yahoogroups.com
> > > > > > Date: Monday, August 15, 2011, 6:07 PM
> > > > > > Really nobody any idea?
> > > > > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@>
> > wrote:
> > > > > > > Hi all,
> > > > > > > Yesterday I tried to activate and change the portamento time
> > > > manually (I
> > > > > > don't have the foggiest idea how to send the proper messages
> > in
> > > > MIDI from my
> > > > > > M-Audio ProKeys).
> > > > used the Menu
> > Inc to
> > > > increase
> > > > > > the portamento.
> > > > > > > Alas to no avail.
> > > > > > > Did I misinterpret the manual?
> > > > > > > Do I make some stupid mistake or omission?
> > > > > > > Advice is highly appreciated.
> > > > > > > Regards,
> > > > > > > Ton
> > > > > > [Non-text portions of this message have been removed]
