HNY & do multiples halve the audio signal?
2012-01-02 by Ton Akveld
Dear group, Just like Bakis I want to wish you all a good 2012! But now, something completely different. When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. Is this caused by a difference in the audio out and multiples connectors? Hope someone can tell. Warm regards, Ton
2012-01-02 by York Luethje
Hi Ton, Happy New Year to you as well. Modular signals are generally mono. An oscillator generates one waveform, not two left and right ones and the following signal chain will thus also be in mono. York _____ Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] Im Auftrag von Ton Akveld Gesendet: Montag, 2. Januar 2012 11:34 An: Doepfer_a100@yahoogroups.com Betreff: [Doepfer_a100] HNY & do multiples halve the audio signal? Dear group, Just like Bakis I want to wish you all a good 2012! But now, something completely different. When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. Is this caused by a difference in the audio out and multiples connectors? Hope someone can tell. Warm regards, Ton [Non-text portions of this message have been removed]
2012-01-03 by marco_zambardi
strange... usually modules use mono jack in and patching them with a stereo cable have no effect since there should be no connection (except for modules with a switch in the jack in to break normalled connection). i have my external mixer bringing the mono-signal to L and R speaker. i will have a try. --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@...> wrote:
> > Dear group, > > Just like Bakis I want to wish you all a good 2012! > > But now, something completely different. > > When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. > However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. > Is this caused by a difference in the audio out and multiples connectors? > Hope someone can tell. > > Warm regards, > > Ton >
2012-01-03 by Ton Akveld
Hi York, Thanks for your prompt reply. I am aware of the mono character of the modular system. So on stereo headphones left and right are the same. What puzzles me is the fact one channel 'disappears' when routing the signal through a multiples. It however dawned on me that might be caused by the difference in the plugs of the headphones cable and the doepfer cables. --- In Doepfer_a100@yahoogroups.com, "York Luethje" <ybl@...> wrote:
> > Hi Ton, > > > > Happy New Year to you as well. Modular signals are generally mono. An > oscillator generates one waveform, not two left and right ones and the > following signal chain will thus also be in mono. > > > > York > > > > _____ > > Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] Im > Auftrag von Ton Akveld > Gesendet: Montag, 2. Januar 2012 11:34 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] HNY & do multiples halve the audio signal? > > > > > > Dear group, > > Just like Bakis I want to wish you all a good 2012! > > But now, something completely different. > > When plugging in headphones in an audio out connector (VCA, mixer) I hear > both the left and right channel. > However, if I route the audio out through a multiples, the audio signal is > halved, only the left channel is left. > Is this caused by a difference in the audio out and multiples connectors? > Hope someone can tell. > > Warm regards, > > Ton > > > > > > [Non-text portions of this message have been removed] >
Hi Marco, Thanks for thinking with me ;-) You write: > i have my external mixer bringing the mono-signal to L and R speaker. Does it still after routing through a multiples? Love to hear! Ton --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@...> wrote:
> > strange... > usually modules use mono jack in and patching them with a stereo cable have no effect since there should be no connection (except for modules with a switch in the jack in to break normalled connection). > > i have my external mixer bringing the mono-signal to L and R speaker. > > i will have a try. > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > Dear group, > > > > Just like Bakis I want to wish you all a good 2012! > > > > But now, something completely different. > > > > When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. > > However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. > > Is this caused by a difference in the audio out and multiples connectors? > > Hope someone can tell. > > > > Warm regards, > > > > Ton > > >
Dear Florian, Thank you for this explanation! This does shed a bright light on my 'problem'. Kind regards, Ton --- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> > The sockets used by Doepfer aren't standard 3.5mm mono sockets (where no > real standard exists), but special sockets, where the ground contact is > more raised to the place, where on a stereo(=headphone) jack the "ring" > contact is. This is no problem with mono jack connectors, but can cause > unpredictable results with stereo jacks - especially as the 3.5mm or > 1/8" jack/socket system is not really normed. > > Florian >
2012-01-03 by Florian Anwander
The sockets used by Doepfer aren't standard 3.5mm mono sockets (where no real standard exists), but special sockets, where the ground contact is more raised to the place, where on a stereo(=headphone) jack the "ring" contact is. This is no problem with mono jack connectors, but can cause unpredictable results with stereo jacks - especially as the 3.5mm or 1/8" jack/socket system is not really normed. Florian
2012-01-04 by marco_zambardi
Hello Tony, yes, my external line mixer (a behringer eurorack pro) get a mono signal (Left/Mono In used) and split it on my Left and Right monitor (of course there is no real stereo fx in this case, the same signal is brought to L and R). this works both in case a multiple is used in patch and in case no multiple is used in the patch. but i always pass through a VCA (intellijel uVCA or Doepfer A-131 exp VCA) as last module before the mixer. Marco --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@...> wrote:
> > Hi Marco, > > Thanks for thinking with me ;-) > > You write: > > i have my external mixer bringing the mono-signal to L and R speaker. > Does it still after routing through a multiples? > > Love to hear! > > Ton > > > --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@> wrote: > > > > strange... > > usually modules use mono jack in and patching them with a stereo cable have no effect since there should be no connection (except for modules with a switch in the jack in to break normalled connection). > > > > i have my external mixer bringing the mono-signal to L and R speaker. > > > > i will have a try. > > > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > > > Dear group, > > > > > > Just like Bakis I want to wish you all a good 2012! > > > > > > But now, something completely different. > > > > > > When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. > > > However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. > > > Is this caused by a difference in the audio out and multiples connectors? > > > Hope someone can tell. > > > > > > Warm regards, > > > > > > Ton > > > > > >
2012-01-04 by Ton Akveld
Hi Marco, Thanks for the description! I route my end signal through a multiples so I can send one to the di-box and amplifier and the other to the oscilloscope (see http://groups.yahoo.com/group/Doepfer_a100/photos/album/1838015066/pic/57965373/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc) Regards, Ton (when in Sicilia: Nino :-)) --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@...> wrote:
> > Hello Tony, > > yes, my external line mixer (a behringer eurorack pro) get a mono signal (Left/Mono In used) and split it on my Left and Right monitor (of course there is no real stereo fx in this case, the same signal is brought to L and R). > > this works both in case a multiple is used in patch and in case no multiple is used in the patch. but i always pass through a VCA (intellijel uVCA or Doepfer A-131 exp VCA) as last module before the mixer. > > Marco > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > Hi Marco, > > > > Thanks for thinking with me ;-) > > > > You write: > > > i have my external mixer bringing the mono-signal to L and R speaker. > > Does it still after routing through a multiples? > > > > Love to hear! > > > > Ton > > > > > > --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@> wrote: > > > > > > strange... > > > usually modules use mono jack in and patching them with a stereo cable have no effect since there should be no connection (except for modules with a switch in the jack in to break normalled connection). > > > > > > i have my external mixer bringing the mono-signal to L and R speaker. > > > > > > i will have a try. > > > > > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > > > > > Dear group, > > > > > > > > Just like Bakis I want to wish you all a good 2012! > > > > > > > > But now, something completely different. > > > > > > > > When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. > > > > However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. > > > > Is this caused by a difference in the audio out and multiples connectors? > > > > Hope someone can tell. > > > > > > > > Warm regards, > > > > > > > > Ton > > > > > > > > > >
2012-01-05 by marco_zambardi
hi tony, forgot to say, i am using Intellijel Buffered Multi, not the A-180. but from the DI then where you plug the signal? --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@...> wrote:
> > Hi Marco, > > Thanks for the description! > I route my end signal through a multiples so I can send one to the di-box and amplifier and the other to the oscilloscope (see http://groups.yahoo.com/group/Doepfer_a100/photos/album/1838015066/pic/57965373/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc) > > Regards, > > Ton (when in Sicilia: Nino :-)) > > --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@> wrote: > > > > Hello Tony, > > > > yes, my external line mixer (a behringer eurorack pro) get a mono signal (Left/Mono In used) and split it on my Left and Right monitor (of course there is no real stereo fx in this case, the same signal is brought to L and R). > > > > this works both in case a multiple is used in patch and in case no multiple is used in the patch. but i always pass through a VCA (intellijel uVCA or Doepfer A-131 exp VCA) as last module before the mixer. > > > > Marco > > > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > > > Hi Marco, > > > > > > Thanks for thinking with me ;-) > > > > > > You write: > > > > i have my external mixer bringing the mono-signal to L and R speaker. > > > Does it still after routing through a multiples? > > > > > > Love to hear! > > > > > > Ton > > > > > > > > > --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@> wrote: > > > > > > > > strange... > > > > usually modules use mono jack in and patching them with a stereo cable have no effect since there should be no connection (except for modules with a switch in the jack in to break normalled connection). > > > > > > > > i have my external mixer bringing the mono-signal to L and R speaker. > > > > > > > > i will have a try. > > > > > > > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > > > > > > > Dear group, > > > > > > > > > > Just like Bakis I want to wish you all a good 2012! > > > > > > > > > > But now, something completely different. > > > > > > > > > > When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. > > > > > However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. > > > > > Is this caused by a difference in the audio out and multiples connectors? > > > > > Hope someone can tell. > > > > > > > > > > Warm regards, > > > > > > > > > > Ton > > > > > > > > > > > > > > >
2012-01-05 by Ton Akveld
Hi Marco, From the DI it goes to the L/MONO input on my amplifier, a Roland KC-110. --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@...> wrote:
> > hi tony, > > forgot to say, i am using Intellijel Buffered Multi, not the A-180. > but from the DI then where you plug the signal? > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > Hi Marco, > > > > Thanks for the description! > > I route my end signal through a multiples so I can send one to the di-box and amplifier and the other to the oscilloscope (see http://groups.yahoo.com/group/Doepfer_a100/photos/album/1838015066/pic/57965373/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc) > > > > Regards, > > > > Ton (when in Sicilia: Nino :-)) > > > > --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@> wrote: > > > > > > Hello Tony, > > > > > > yes, my external line mixer (a behringer eurorack pro) get a mono signal (Left/Mono In used) and split it on my Left and Right monitor (of course there is no real stereo fx in this case, the same signal is brought to L and R). > > > > > > this works both in case a multiple is used in patch and in case no multiple is used in the patch. but i always pass through a VCA (intellijel uVCA or Doepfer A-131 exp VCA) as last module before the mixer. > > > > > > Marco > > > > > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > > > > > Hi Marco, > > > > > > > > Thanks for thinking with me ;-) > > > > > > > > You write: > > > > > i have my external mixer bringing the mono-signal to L and R speaker. > > > > Does it still after routing through a multiples? > > > > > > > > Love to hear! > > > > > > > > Ton > > > > > > > > > > > > --- In Doepfer_a100@yahoogroups.com, "marco_zambardi" <marco.zambardi@> wrote: > > > > > > > > > > strange... > > > > > usually modules use mono jack in and patching them with a stereo cable have no effect since there should be no connection (except for modules with a switch in the jack in to break normalled connection). > > > > > > > > > > i have my external mixer bringing the mono-signal to L and R speaker. > > > > > > > > > > i will have a try. > > > > > > > > > > --- In Doepfer_a100@yahoogroups.com, "Ton Akveld" <aca@> wrote: > > > > > > > > > > > > Dear group, > > > > > > > > > > > > Just like Bakis I want to wish you all a good 2012! > > > > > > > > > > > > But now, something completely different. > > > > > > > > > > > > When plugging in headphones in an audio out connector (VCA, mixer) I hear both the left and right channel. > > > > > > However, if I route the audio out through a multiples, the audio signal is halved, only the left channel is left. > > > > > > Is this caused by a difference in the audio out and multiples connectors? > > > > > > Hope someone can tell. > > > > > > > > > > > > Warm regards, > > > > > > > > > > > > Ton > > > > > > > > > > > > > > > > > > > > >
2012-01-09 by yahoo@doepfer.de
> Dear group, > > Just like Bakis I want to wish you all a good 2012! > > But now, something completely different. > > When plugging in headphones in an audio out connector (VCA, > mixer) I hear both the left and right channel. > However, if I route the audio out through a multiples, the audio > signal is halved, only the left channel is left. > Is this caused by a difference in the audio out and multiples connectors? > Hope someone can tell. > > Warm regards, > > Ton Also from me Best Wishes for the New Year! The mechanical construction of monophonic 3.5 mm jacks and plugs is different from stereophonic versions. Parts of the long GND sector of the monophonic versions is used in the stereophonic versions as the second signal. It depends upon the mechanical tolerances and the plug-in depth what happens if a stereophonic plug is connected to a monophonic socket. Typically the second stereo signal will be dead as the corresponding sector of the plug is not connected or connected to GND (depends upon the mechanical details of the monophonic jack socket). But there might be an intermediate plug-in position where the monophonic signal appears on both stereo channels. As there exists no technical specification that describes what happens if a 3.5 mm stereo plug is connected to a monophonic 3.5 mm socket you will have to try it out. In the A-100 two different 3.5 mm sockets are used (vertical and horizontal) and maybe they behave different. Best wishes Dieter Doepfer
2012-01-09 by james.husted@mac.com
This happens because the GND is shared in the headphone for each channel and where a mono jack that has a plastic shell and instead of connecting with the shell, uses a connection that normally is where the ring is on a stereo plug. The jack connects to the ring of the headphones (expecting to connect to the shaft of the mono plug) and you get what appears to be a mono signal but is in fact both left and right being connected serially (through the shared ground). The ground being connected together and the ring connecting to the true ground. Positive jack to left positive, left negative (shared GND) to right negative (shared GND) to right positive to mono jack GND (instead of ring). This happens on headphones because they share the single ground for both left and right. -James
On Jan 9, 2012, at 4:06 AM, yahoo@doepfer.de wrote: >> Dear group, >> >> Just like Bakis I want to wish you all a good 2012! >> >> But now, something completely different. >> >> When plugging in headphones in an audio out connector (VCA, >> mixer) I hear both the left and right channel. >> However, if I route the audio out through a multiples, the audio >> signal is halved, only the left channel is left. >> Is this caused by a difference in the audio out and multiples connectors? >> Hope someone can tell. >> >> Warm regards, >> >> Ton > > Also from me Best Wishes for the New Year! > > The mechanical construction of monophonic 3.5 mm jacks and plugs is > different from stereophonic versions. Parts of the long GND sector of the > monophonic versions is used in the stereophonic versions as the second > signal. It depends upon the mechanical tolerances and the plug-in depth what > happens if a stereophonic plug is connected to a monophonic socket. > Typically the second stereo signal will be dead as the corresponding sector > of the plug is not connected or connected to GND (depends upon the > mechanical details of the monophonic jack socket). But there might be an > intermediate plug-in position where the monophonic signal appears on both > stereo channels. > > As there exists no technical specification that describes what happens if a > 3.5 mm stereo plug is connected to a monophonic 3.5 mm socket you will have > to try it out. In the A-100 two different 3.5 mm sockets are used (vertical > and horizontal) and maybe they behave different. > > Best wishes > Dieter Doepfer > > > > > > ------------------------------------ > > Yahoo! Groups Links > > >
2012-01-10 by Ton Akveld
Dear Dieter, Thank you for the elaborate explanation. --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > > Dear group, > > > > Just like Bakis I want to wish you all a good 2012! > > > > But now, something completely different. > > > > When plugging in headphones in an audio out connector (VCA, > > mixer) I hear both the left and right channel. > > However, if I route the audio out through a multiples, the audio > > signal is halved, only the left channel is left. > > Is this caused by a difference in the audio out and multiples connectors? > > Hope someone can tell. > > > > Warm regards, > > > > Ton > > Also from me Best Wishes for the New Year! > > The mechanical construction of monophonic 3.5 mm jacks and plugs is > different from stereophonic versions. Parts of the long GND sector of the > monophonic versions is used in the stereophonic versions as the second > signal. It depends upon the mechanical tolerances and the plug-in depth what > happens if a stereophonic plug is connected to a monophonic socket. > Typically the second stereo signal will be dead as the corresponding sector > of the plug is not connected or connected to GND (depends upon the > mechanical details of the monophonic jack socket). But there might be an > intermediate plug-in position where the monophonic signal appears on both > stereo channels. > > As there exists no technical specification that describes what happens if a > 3.5 mm stereo plug is connected to a monophonic 3.5 mm socket you will have > to try it out. In the A-100 two different 3.5 mm sockets are used (vertical > and horizontal) and maybe they behave different. > > Best wishes > Dieter Doepfer >
Dear James, Thank you too for explaining in detail. --- In Doepfer_a100@yahoogroups.com, james.husted@... wrote:
> > This happens because the GND is shared in the headphone for each channel and where a mono jack that has a plastic shell and instead of connecting with the shell, uses a connection that normally is where the ring is on a stereo plug. The jack connects to the ring of the headphones (expecting to connect to the shaft of the mono plug) and you get what appears to be a mono signal but is in fact both left and right being connected serially (through the shared ground). The ground being connected together and the ring connecting to the true ground. Positive jack to left positive, left negative (shared GND) to right negative (shared GND) to right positive to mono jack GND (instead of ring). This happens on headphones because they share the single ground for both left and right. > -James > > On Jan 9, 2012, at 4:06 AM, yahoo@... wrote: > > >> Dear group, > >> > >> Just like Bakis I want to wish you all a good 2012! > >> > >> But now, something completely different. > >> > >> When plugging in headphones in an audio out connector (VCA, > >> mixer) I hear both the left and right channel. > >> However, if I route the audio out through a multiples, the audio > >> signal is halved, only the left channel is left. > >> Is this caused by a difference in the audio out and multiples connectors? > >> Hope someone can tell. > >> > >> Warm regards, > >> > >> Ton > > > > Also from me Best Wishes for the New Year! > > > > The mechanical construction of monophonic 3.5 mm jacks and plugs is > > different from stereophonic versions. Parts of the long GND sector of the > > monophonic versions is used in the stereophonic versions as the second > > signal. It depends upon the mechanical tolerances and the plug-in depth what > > happens if a stereophonic plug is connected to a monophonic socket. > > Typically the second stereo signal will be dead as the corresponding sector > > of the plug is not connected or connected to GND (depends upon the > > mechanical details of the monophonic jack socket). But there might be an > > intermediate plug-in position where the monophonic signal appears on both > > stereo channels. > > > > As there exists no technical specification that describes what happens if a > > 3.5 mm stereo plug is connected to a monophonic 3.5 mm socket you will have > > to try it out. In the A-100 two different 3.5 mm sockets are used (vertical > > and horizontal) and maybe they behave different. > > > > Best wishes > > Dieter Doepfer > > > > > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > >
2012-01-10 by yahoo@doepfer.de
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Ton Akveld > Gesendet: Dienstag, 10. Januar 2012 16:55 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] Re: HNY & do multiples halve the audio signal? > > > Dear Dieter, > > Thank you for the elaborate explanation. You'r welcome. Wikipedia has a picture available that shows the monophonic and stereophonic plugs in detail: http://en.wikipedia.org/wiki/File:Photo-audiojacks.jpg and http://en.wikipedia.org/wiki/TRS_connector From the picture you can see that the second signal terminal (ring) overlaps with the isolator and the GND terminal of the monophonic version. It depends upon the mechanical construction of the monophonic jack socket (i.e. the exact positions of the spring contacts) what will happen. For monophonic plugs there is much tolerance as e.g. the GND spring can be elsewhere in the sleeve area and the signal spring has to touch the tip of the plug. If a stereophonic plug is inserted into a monophonic socket all depends upon the positions of the springs of the socket relative to the sectors of the plug. The tip connection is usually no problem. But the position of the GND spring of the socket decides what will happen if a stereophonic plug is used. Best wishes Dieter Doepfer
