2½ years later... the problem was with the cliff jack that did not close the connection for the tip. Removed the old one and put a new one there, the A-155 works as it should!
I had the same problem with a A-143-2 where one of the four ADSR-channes did not react to gates sent to the first jack, the other three worked as they should. Swap the jack for a new one and it works fine!
/Janne
> To: doepfer_a100@yahoogroups.com
> From: tapirkillen@hotmail.com
> Date: Fri, 24 Aug 2012 15:19:19 +0200
> Subject: RE: [Doepfer_a100] Re: Troubleshooting A-155
> I have tried with external signal in for the offending pot, but to no avail. Still nothing happens. Its value is still zero, no matter what I send as external signal.
> As far as I remember I tried tracing all connections with the multimeter, comparing to the working row of pots, but could not find any difference. But I will check once more and see what might turn up.
> /Janne
> To: Doepfer_a100@yahoogroups.com
> From: richyho@virginmedia.com
> Date: Fri, 24 Aug 2012 14:11:22 +0100
> Subject: [Doepfer_a100] Re: Troubleshooting A-155
> Hi
> It could be a problem with the jack socket below the pot instead of the pot
> itself. I believe that when a lead is plugged into this the knob becomes an
> attenuator of this signal. If the socket 'thinks' a cable is plugged in
> then that knob may be attenuating zero volts so not doing anything. This
> can happen when the metal contacts in the socket become damaged and touch
> even when nothing is plugged in. You need to check continuity with a
> multimeter, comparing the results with another working socket. Quite a
> simple fix with a small screwdriver if this is the case.
> Rich
> Hi everyone!
> I have got an A-155 sequencer where one of the pots on the bottom row does
> not work. At all.
> In order to try to pin down the error I have swapped the ICs from the top
> row to the bottom row (http://www.doepfer.de/A100_pictures/doepfer_a155.jpg,
> the two PCBs with the knobs), but the problem was still there. Is there
> anything else I can do? I have also tried to measure resistance what is
> happening when turning the pot, but I did not see anything that made the
> offending pot differ from working pots.
> Is the pot itself broken, or is there anything else I should try to pin
> down the problem?
> Modular regards,
> Janne
> <*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/Doepfer_a100/
> <*> Your email settings:
> Individual Email | Traditional
> <*> To change settings online go to:
> http://groups.yahoo.com/group/Doepfer_a100/join
> (Yahoo! ID required)
> <*> To change settings via email:
> Doepfer_a100-digest@yahoogroups.com
> Doepfer_a100-fullfeatured@yahoogroups.com
> <*> To unsubscribe from this group, send an email to:
> Doepfer_a100-unsubscribe@yahoogroups.com
> <*> Your use of Yahoo! Groups is subject to:
