Doepfer
Question about daisy-chain of MIDI modules
2013-01-01 by David Kaiser
I have a A-190-3 USB/Midi to CV interface
(http://www.doepfer.de/a1903.htm), and recently picked up a A-190-2 Midi
to CV interface (http://www.doepfer.de/a1902.htm) as well.
I'm hoping to daisy-chain the serial MIDI data between the two modules,
so I can use one MIDI (or USB) cable to my rack, train the 190-3 for one
MIDI channel, and train the 190-2 for another MIDI channel, but only use
a single MIDI cable as input to my rack for both modules.
The Doepfer web site offers an 'excerpt' or single-page of the A-190-3
manual (the "p13" PDF).  It has two "jumpers" (dual pins), JP5 for MIDI
OUT, and JP6 for MIDI In.  And it looks that a 2-wire cable can be used
for serial transfer like MIDI.
In the PDF for the A-190-2, there is one jumper set, JP5, with only two
pins.  It is labeled for both MIDI IN and MIDI OUT.
I'm assuming the serial data used in both devices is raw MIDI
(transmit/receive) as you would see through signal analysis of a MIDI cable.
Is there a recommended approach to use JP5 (MIDI OUT) from the A-190-3
and lead it to only one pin of JP5 on the A-190-2 for MIDI IN purposes?
In the A-190-3 PDF
(http://www.doepfer.de/a100_man/A190_3_Manual_p13.pdf) one pin of each
JP5 and JP6 is marked with a 'T' symbol, and this pin is soldered to the
ground plane on the circuit board.
Does the A-190-3 module tie the 'T'-marked pins of JP5/JP6 to frame
ground through the A-100 System cable?
Is the frame ground how to make up for the lack of the second wire on
the A-190-2?
I am going to try doing a one-wire daisy chain between the A-190-3 out
to the A-190-2.  Will it work?  Has anyone confirmed this?
Thanks for any help, and have a Happy New Year!
David
Re: [Doepfer_a100] Question about daisy-chain of MIDI modules
2013-01-01 by achtung_999
What you want is a Midi Thru connector. As I can see both the 190-2 and
190-3 don't have a Thru connector.
Best thing you can do is buy an active midi thru box like a Philip Rees or
so. http://www.philrees.co.uk/products/thruunit.htm
> cable.
> In the A-190-3 PDF
> the A-190-2?
> David
2013-01-01 by anthony.box@talk21.com
Regret to say Philip Rees stopped trading years ago. I still have one of their MIDI devices but recently changed over to MUTU.
http://www.wizardwoodcraft.co.uk/
Norfolk UK
From: achtung_999 <heinrich.himmelwasser@gmail.com>
>To: Doepfer_a100@yahoogroups.com
>Sent: Tuesday, 1 January 2013, 9:37
>Subject: Re: [Doepfer_a100] Question about daisy-chain of MIDI modules
>> cable.
>> In the A-190-3 PDF
>> the A-190-2?
>> David
>Yahoo! Groups Links
Re: Question about daisy-chain of MIDI modules
2013-01-01 by woof_dave
I bought a Kenton Thru-5 MIDI thru unit a couple of weeks ago, and it does the job perfectly.  Pretty good value too.
Dave.
--- In Doepfer_a100@yahoogroups.com, achtung_999 <heinrich.himmelwasser@...> wrote:
> Sorry to hear that Philip Rees is out of business. But I think Kenton makes
> excellent stuff too.
> http://www.kentonuk.com/products/select/midi-utilsel.shtml
> > Norfolk UK
> > From: achtung_999 <heinrich.himmelwasser@...>
> > Midi
> > >> cable.
> > >> In the A-190-3 PDF
> > >> the A-190-2?
> > >> David
> > >Yahoo! Groups Links
> Norfolk UK
> Midi
> >> cable.
> >> In the A-190-3 PDF
> >> the A-190-2?
> >> David
> >Yahoo! Groups Links
2013-01-02 by David Kaiser
I understand the intent of the standard "MIDI Thru' connector, but I am
trying to follow an approach that requires less external gear.
In this case, Doepfer has provided headers on the PCB (printed circuit
board) on the backside of the modules, to allow you to daisy-chain
multiple A-190-(2/3) interfaces together, thus replacing an external
Thru cable with an internal wire.   This approach is partially
documented in the PDF's that I referenced.
I will make the cable and test it myself and report back on how it works.
>> cable.
>> In the A-190-3 PDF
>> the A-190-2?
>> David
2013-01-02 by achtung_999
Ah I was not aware of that! Classy!
> or
> Midi
> >> cable.
> >> In the A-190-3 PDF
> >> the A-190-2?
> >> David
> > Yahoo! Groups Links
AW: [Doepfer_a100] Question about daisy-chain of MIDI modules
2013-01-07 by yahoo@doepfer.de
You may simply connect the "hot" midi output signal (i.e. not the GND pin)
of the first module to the "hot" midi input of the second module. Connecting
the GND is not required as the GND connection is made via the A-100 bus.
That way the second module received the same Midi signal as the first module
because the Midi output is nothing but Midi thru unless the "stack mode" is
not used. Only the "stacked" Midi notes are missing at the Midi output.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von David Kaiser
> Gesendet: Dienstag, 1. Januar 2013 01:33
> Betreff: [Doepfer_a100] Question about daisy-chain of MIDI modules
> MIDI cable.
> In the A-190-3 PDF
> the A-190-2?
> David
Re: AW: [Doepfer_a100] Question about daisy-chain of MIDI modules
2013-01-20 by David Kaiser
Thank you Dieter!   That is the confirmation that I was looking for.
> Connecting
> module
> mode" is
> Best wishes
> Dieter Doepfer
> <mailto:Doepfer_a100%40yahoogroups.com>
> <mailto:Doepfer_a100%40yahoogroups.com>]Im Auftrag von David Kaiser
> > An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> > MIDI cable.
> > In the A-190-3 PDF
> > the A-190-2?
> > David
> > Yahoo! Groups Links
