On Feb 6, 2013, at 3:59 AM, charles kerr <thebadproducer@yahoo.co.uk> wrote:
> Hi James,
> I'd be interested to see your expansion circuit if possible, sounds like a cool addition to the 152! Would it be possible to email it to me or drop it into the file box?
> Thanks,
> Charlie
> --- On Mon, 4/2/13, James Husted <james.husted@mac.com> wrote:
> From: James Husted <james.husted@mac.com>
> Subject: Re: [Doepfer_a100] Can I mod a A-152 to do this?
> To: Doepfer_a100@yahoogroups.com
> Date: Monday, 4 February, 2013, 18:26
> Forgot - no attachments in this forum! basically The thing I attached was a transistor circuit (2N5088) and some resistors and a LED to drive the output jack. It should isolate the processor fine. I will attach it to the expansion header so no mods to the board itself. That is why I asked about what else is on that header. Might as well bring out whatever I can since I will be making a panel for it.
> -James
> On Feb 4, 2013, at 10:21 AM, James Husted james.husted@mac.com> wrote:
>> Thank You Dieter! I was sure that something like this was available. I will probably make something like this to attach to it:
>> Nice that it is on an expansion connector too. What else shows up on that expansion connector?
>> -James
>> On Feb 4, 2013, at 1:26 AM, yahoo@doepfer.de wrote:
>>>> -----Ursprungliche Nachricht-----
>>>> Von: Doepfer_a100@yahoogroups.com
>>>> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von James Husted
>>>> Gesendet: Samstag, 2. Februar 2013 08:41
>>>> An: Doepfer_a100@yahoogroups.com
>>>> Betreff: [Doepfer_a100] Can I mod a A-152 to do this?
>>>> I recently got an A-152 and am using it to select the columns of
>>>> two of my PGM-4X4 programmers to make sequences that can have
>>>> programmable patterns to them. What I would like is to mod the
>>>> A-152 so that I can add an output that produces a trigger
>>>> whenever the A-152 addresses a new step. This way something like
>>>> a sine wave into the A-152 would make the PGM-4X4 work like a
>>>> pendulum and would also produce triggers to fire off envelope
>>>> generators whenever a new address/column/note happened. Is there
>>>> some internal circuit logic that can be added to create a trigger
>>>> out like this?
>>> This is also available as an internal "hidden" feature since about 2005.
>>> The RC4 port pin of the microcontroller (pin 6) outputs a short pulse
>>> whenever the address changes. The signal is also available at the expansion
>>> connector on pin 2. Pay attention that the signal is not buffered and not
>>> protected against short or electrostatic charge (it's the "pure" RC4 port
>>> signal). The microprocessor will be damaged if a voltage or GND is applied
>>> to this pin. You have to add a suitable buffer to protect the processor. Do
>>> not simply connect it to a socket !
>>> Best wishes
>>> Dieter Doepfer
>>> Yahoo! Groups Links
>> [Non-text portions of this message have been removed]
>> Yahoo! Groups Links
