Doepfer
Re: Dark Energy not responding to midi
2013-02-04 by Robert Crouch
Yes I did. The problem is fairly consistent where it received midi fine until it's been plugged in for a while, then it just stops. I have to unplug it for anywhere between 10 and 30 minutes before it starts working again.
I should probably send it to Analogue Haven and have them look at it.
--- In Doepfer_a100@yahoogroups.com,  wrote:
> Did you (re-)install a jumper to the pin header JP4 on the interface/supply
> board instead of the glide option ?
> Best wishes
> Dieter Doepfer
> > -----Ursprüngliche Nachricht-----
> > Von: Doepfer_a100@yahoogroups.com
> > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Robert Crouch
> > Gesendet: Freitag, 1. Februar 2013 19:03
> > An: Doepfer_a100@yahoogroups.com
> > Betreff: [Doepfer_a100] Re: Dark Energy not responding to midi
> > Turns out it's not the glide option after all.
> > I think I need to send it in for repair.
> > --- In Doepfer_a100@yahoogroups.com, "Robert Crouch"  wrote:
> > > I installed the glide kit to my Dark Energy a while ago and
> > lately the internal midi-cv converter has been giving me
> > problems. Every so often it just stops responding to any incoming
> > midi signal, either through the USB or midi ports. I reinstalled
> > the glide control and that seems to clear it up, and every so
> > often I would have to remove and reinstall the thing to get the
> > unit to respond to midi.
> > > Today it stopped responding at all, so to troubleshoot it I
> > decided to remove the glide knob to see if maybe it's faulty. In
> > order to install the glide I had to remove in internal jumper,
> > and now I can't find it where I stored it. Does anyone know off
> > hand what kind of jumper I need to buy?
> > > Also if this is not a case of a bad glide knob, is there any
> > place in the US that can repair the unit or will it need to be
> > sent back to Doepfer?
> > > Thanks in advance for the advice!
> > Yahoo! Groups Links
AW: [Doepfer_a100] Re: Dark Energy not responding to midi
2013-02-05 by yahoo@doepfer.de
Yes, please return the unit for repair and add a short description of the
fault. Maybe it's a thermal problem.
Thank you
Dieter Doepfer
