Re: Dark Energy not responding to midi
2013-02-01 by Robert Crouch
Turns out it's not the glide option after all. I think I need to send it in for repair. :-( --- In Doepfer_a100@yahoogroups.com, "Robert Crouch" wrote:
> > I installed the glide kit to my Dark Energy a while ago and lately the internal midi-cv converter has been giving me problems. Every so often it just stops responding to any incoming midi signal, either through the USB or midi ports. I reinstalled the glide control and that seems to clear it up, and every so often I would have to remove and reinstall the thing to get the unit to respond to midi. > > Today it stopped responding at all, so to troubleshoot it I decided to remove the glide knob to see if maybe it's faulty. In order to install the glide I had to remove in internal jumper, and now I can't find it where I stored it. Does anyone know off hand what kind of jumper I need to buy? > > Also if this is not a case of a bad glide knob, is there any place in the US that can repair the unit or will it need to be sent back to Doepfer? > > Thanks in advance for the advice! >
