Re: A-183-1
2013-03-31 by Syndromeda
Thanks Rich, Very helpfull again, so I will not buy this A-183-1. Cheers, Danny --- In Doepfer_a100@yahoogroups.com, Richard Horsman <richyho@...> wrote:
> > Hi Danny > > Yes, you could use an A-138 in place of an A-183-1 to attenuate a > single signal. It also gives you the added bonus of being able to > offset that signal by up to 5V - If you don't plug your signal in to > channel 1 then that channel's knob will add up to 5V to your signal at > the output. > > If it's audio you're attenuating then the 138b is moreusefual than the > 138a as it has an exponential response, rather then then a's linear > one. > > This from Doepfer's site... > > "From April 2004 an improved version of the module A-138b is > manufactured. For the revised versions control In1 works as a DC > offset generator (about 0...+5V) provided that no patch cord is > plugged into socket In1. If this feature is not required it can be > deactivated by removing a jumper on the pc board. Probably from summer > 2004 even the A-138a will be manufactured with this improvement." > > The 183-1's nice though as it gives you 2 passive independent > attenuators in just 4hp. Note that these are also VERY easy to build > yourself - probably the most common first DIY project for Eurorack. > Just 2 jacks and a pot for each attenuator. Cheap and cheerful! > > Hope this helps > > Rich > > > > > > Hi, > Can someone tell me what's the difference between a A-138 Mixer and a > 183-1 Attenuator, or is it only the difference between active and > passive, so I could use a A-138 instead of a A-183-1. > TIA, > Danny >
