Doepfer
pseudo stereo effects thread.
2013-04-07 by Peter Sedin
In DAWS to spread/wide a mono-sound I copy one channel and dealy the copied
channel a bit.. and pan both of them a bit sometimes.. and sometimes ues
diffrent filter on them. This is a classic way to get a wide sound.. how do
I do this in the modular world? is there a easy way to do this? can i use
a-180 standrad multilples to copy sound sources? any thought and ideas are
welcome here.
peace.
Mvh
Peter H.K Sedin
Re: [Doepfer_a100] pseudo stereo effects thread.
2013-04-07 by Jakob Paulussen
I use the panning module A-134. It has separate left and right outputs and
2 CV inputs. With those you can also create interesting panning effects.
Cheers
Jakob
 Am 07.04.2013 08:59 schrieb "Peter Sedin" <peterhksedin@gmail.com>:
> welcome here.
> peace.
> Mvh
> Peter H.K Sedin
Fwd: [Doepfer_a100] pseudo stereo effects thread.
thanks, yes. really fast mod source might archive that widening I´m after
yes?
Cheers
Jakob
copied
do
> welcome here.
> peace.
> Mvh
> Peter H.K Sedin
Yahoo! Groups Links
Mvh
Peter H.K Sedin
Re: Fwd: [Doepfer_a100] pseudo stereo effects thread.
Basically yes. It has 2 outputs which go into 2 different channels on your
mixing desk side by side on pan to far left, one to far right. The module
has 2 inputs as well. Depending on the sounds you create e.g. if you make
pads or drone like sounds you can lay wide carpet-like sounds and add an
LFO to modulate the panning. Or have a short sequencer like sound bop
through the stereo panorama in whatever fashion you like.
The A134 module is a great module for anything stereo and/or panning.
Cheers
Jakob
Am 07.04.2013 09:21 schrieb "Peter Sedin" <peterhksedin@gmail.com>:
> thanks, yes. really fast mod source might archive that widening I�m after
> yes?
> Hi,
> Cheers
> Jakob
> copied
> do
> are
> > welcome here.
> > peace.
> > Mvh
> > Peter H.K Sedin
> Mvh
> Peter H.K Sedin
2013-04-07 by Richard van der Meer
Peter,
i make use of the wonderfull Flame FX6, that has seperate L and R ins and
outs.
and has a very nice Reverb, chorus and flanger  i can really recommend that
one.
and with only mono in you can have a bit of stereo sense by these effects.
and it's only 99euro
so that's one way, maybe not exactly what you want, but you could always
include it in your chain
since modular Reverbs are hard to find.
well i will be following this post just to get some additional ideas.
Good post anyway. Happy tweaking!
regards
Richar
2013/4/7 Peter Sedin <peterhksedin@gmail.com>
> welcome here.
> peace.
> Mvh
> Peter H.K Sedin
*Met vriendelijke groet / regards*
*Richard van der Meer*
*check out my music at:*
http://www.youtube.com/ricardodilago
http://soundcloud.com/ricardo-di-lago
2013-04-07 by Zoë Blade
Flanging, chorusing, phasing and the like are very similar to that effect, so you may want to look into the A-125 or the lower numbered A-188-1s.
There are other ways of widening a sound too.  After watching the making of Nirvana's Nevermind, I just started doing what apparently pretty much everyone used to do, which is recording some parts twice, and panning the two recordings separately.  This works particularly well with slightly unstable modules like the A-106-1, which will sound everso slightly different on each take, giving you an interesting stereo effect.  The only hard part then is to replicate all your expert knob twiddling in each take, but if you need to do it precisely, you can always draw the movements in your DAW and send them out over MIDI CC channels via a good MIDI to CV converter such as the venerable MCV-24.
The technique you're doing, duplicating the exact recording and offsetting it slightly, is also good, and can just as easily be done with recordings of modulars.  Personally, I wouldn't try to change that technique by replacing the DAW with a module or two.  I think a modular synth is a fine instrument, but a DAW is still necessary to do the actual recording and editing. :)
yes..I also do that in daw, slightly delay one channel and panning..bur
right now I�m not using a computer at all for music, I do all my work from
there so when I make music i like to get away from it!
thanks for your answers :)
editing. :)
Mvh
Peter H.K Sedin
2013-04-07 by James Husted
Another way to do stereo from mono is with a multi-mode filter. Plug the High Pass into one channel and the Low Pass into the other. Use a LFO to move it around. For fun 2 different multi-modes can be used and the LP and HP channels reversed. The Phasing will do some wild stuff if the source is the same for both. Also if the multi-mode has separate band pass and notch, those can be patched left and right for neat effects to. Don't forget to play with the resonance.
-James
James Husted
Designer, Synthwerks LLC
www.synthwerks.com
james@synthwerks.com
synthwerks@me.com
nice on!
2013/4/7 James Husted <james.husted@mac.com>
> -James
> James Husted
> www.synthwerks.com
> synthwerks@me.com
Mvh
Peter H.K Sedin
