MORE INFO FROM DOEPFER ABOUT THE NEW SEQ CONTROLLER !!!
2002-11-04 by bakis Sirros
DIETER SAYS: " Concerning the new A-155 controller it would be important for us which kind of "user interface" the members prefer. E.g. the type of running mode selection a) manual control by a rotary switch b) manual control with up/down buttons b) controlled with up/down inputs (each pulse selects the next running mode) c) voltage controlled d) separate clock inputs for clock forward and clock backward instead of one of the selection modes above or e) only one clock input and another (digital) input to select the direction up/down All these selection types are alternative (i.e. they exclude one another). We need to know which is the prefered way to select the running mode. I think that the voltage controlled selection is the best way (with manual control and CV input with attenuator, e.g. 0...1V = forward / 1...2V = backward / 2...3V = pendulum 1 / 3...4V = pendulum 2 / 4...5V = voltage controlled adressing of the sequencer step. But this would exclude the possibility of separate clocks for up and down as desired by some users. And in case of voltage controlled mode selection or selection with up/down buttons or inputs: which is the best order of the different running modes that correspond to the control voltage (maybee different orders that are programmed by the user - a bit like the filter orders for the A-107). And I think a display of the selected running mode is necessary for voltage controlled mode selection. And which running modes are necessary (2 different pendulum modes like MAQ ? One Shot ? ...) How about a voltage controlled clock source integrated into the new sequencer controller ? A lot of questions, I know. But there are so many possibilities to built a new sequencer controller and we need to know which features and which "user interface" the members would prefer. Kind regards Dieter Doepfer Doepfer Musikelektronik GmbH http://www.doepfer.de email: hardware@doepfer.de SO,I'LL PROBABLY MAKE A POLL ABOUT THE VARIOUS POSSIBLE FEATURES OF THIS NEW SEQ CONTROLLER,OK?? BAKIS. ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner-moderator __________________________________________________ Do you Yahoo!? HotJobs - Search new jobs daily now http://hotjobs.yahoo.com/
