Doepfer
Skip-step
Skip-step
2013-12-26 by draks@apollo111.demon.co.uk
Does the MAQ 16/3 have this function?
Thanks
Anoop
Re: [Doepfer_a100] Skip-step
2013-12-26 by Nicholas Keller
Unfortunately, it does not.  There are ways to achieve this feature by using a complex arrangement of midi commands, but nothing is possible via the front panel.  Using the midi commands would be cumbersome and would likely restrict your workflow.
Nick
Sent from the future
> Thanks
> Anoop
Nick does software version 3 have a step off function?
This would only be useful if it was front panel usable.
The MAQ needs 3 pole switches on each step like the dark time.
2013-12-27 by electr-ohm
I think it can programming on single step mode.
2013/12/27 7:12、<draks@apollo111.demon.co.uk> のメッセージ:
2013-12-27 by draks@apollo111.demon.co.uk
Thanks for the reply.
I could do with details as it will influence whether I order a MAQ or 2 x Dark Times.
I would like to be able to skip and bring back a step in a live situation.
Thanks Anoop
2013-12-27 by Nicholas Keller
You could set up a midi controller to turn a step's value on and off, but not skip.  You can turn it off via front panel if in PA1-5 modes, as fully clockwise = off/mute, but then you can't easily return to the original value.  If you really want more hands-on control and easy setup, go with the Dark Times.  I think with the DTs you'll also get shuffle and glide, but I don't recall off hand.
Nick
> Thanks Anoop
AW: [Doepfer_a100] Skip-step
2014-01-07 by yahoo@doepfer.de
First of all: A happy New Year to all members. I'm back from the
Christmas/New Year break and will answer all questions little by little.
The MAQ has no skip function but only a step off function (available via the
single step). For live situations that's not very handy and I'd recommend
the Dark Time.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von
> Gesendet: Freitag, 27. Dezember 2013 09:30
> Betreff: Re: [Doepfer_a100] Skip-step
> Thanks Anoop
Re: AW: [Doepfer_a100] Skip-step
2014-01-07 by Scott Rogers
Hey Dieter
I just want to say welcome back and thanks for
all the hard work! We really do appreciate it and love the modules!
Scott
>the Dark Time.
>Best wishes
>Dieter Doepfer
> > Thanks Anoop
>Yahoo Groups Links
