Thanks, I would rather not use it in the a-100 system but I wanted to use a couple of A-180-2's as a mini patchbay in my Doepfer-rack to connect some FX, so desolder the circuit boards so I was hoping they were stereo. I hope you understand.
Thanks, regards,
Danny Budts
info@syndromeda.be
www.syndromeda.be
----- Oorspronkelijk bericht -----
Van: "Florian Anwander fanwander@mnet-online.de [Doepfer_a100]" <Doepfer_a100@yahoogroups.com>
Aan: "Doepfer a100" <Doepfer_a100@yahoogroups.com>
Verzonden: Dinsdag 7 oktober 2014 15:40:31
Onderwerp: Re: [Doepfer_a100] Sockets A-180-2
And it is important: The doepfer sockets rely on that you are using a
cable with a mono plug!
Simply hold a stereo plug aside a doepfer socket and you will see, that
the ground connector of the Doepfer socket contacts the shaft of the
plug where the ring of a stereo plug is located:
see http://fa.utfs.org/diy/a100/doepfer_socket_jack.jpg
This does not matter for mono cables. But if you will connect such a
stereo cable with a socket, that picks the ground from the real shaft
position, then the ground will be missing in this connection.
Florian
On 07.10.14 15:02 , Kai Niggemann logiclist@kainiggemann.com
[Doepfer_a100] wrote:
> Mono.
> On 07.10.2014, at 14:56, "syndromeda@telenet.be wrote:
>> Does anybody knows if the sockets used on the Multiple A-180-2 are
>> mono or stereo?
