Fwd: AW: [Doepfer_a100] Re: A155 range input mod
2002-11-18 by bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: AW: [Doepfer_a100] Re: A155 range input mod > Date: Mon, 18 Nov 2002 09:06:41 +0100 > > > in fact,i think i know why it was implemented:the > > moded,newer a155's can work with imperfect pulse > clock > > signals now.they can now use even triangle or saw > > waves as clock signals and work totaly normal(not > in > > the random way that the older a155's work).also,if > you > > use the a155 with the step button you can really > move > > forwards one step at a time and not many steps at > one > > button push(as the older a155's like to > > behave...).BUT,i prefer my a155's to work on audio > > frequencies and behave like crazy when i clock > them > > with triangle or saw waves!!!! > > AM I RIGHT ON ALL THESE ,DIETER?? > > As far as I remember (I'm not sure - forgive me if > I'm wrong, I cannot know each > technical detail in all of our products) there was > introduced a low pass filter > in the A-155 clock because of multiple triggers > caused by the manual step > button. This ensures that no multiple triggers could > come from the manual step > button. But on the other hand this low pass lowers > the maximum clock frequency > at the clock input socket. > > But as Roland Mayer (technik@doepfer.de) has > introduced this modification please > contact him if you want to know details. > > Best regards > Dieter Doepfer > Doepfer Musikelektronik GmbH > http://www.doepfer.de > email: hardware@doepfer.de > ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner-moderator __________________________________________________ Do you Yahoo!? Yahoo! Web Hosting - Let the expert host your site http://webhosting.yahoo.com
