Doepfer
Manual gate with A140 adsr
2016-05-26 by jaccoville@yahoo.com
Hello there,
I would like to make a small switch on my A140 adsr modules.
Looking at some Moog adsr modules I like the idea having a momentary switch to make a fast and easy way to tune the timing with a manual gate.
Anyone has experience with this mod?
I guess I'll have to find a 5V(?) voltage from the pcb or maybe 12V with a resistor?
Cheers from Holland
Jacco Ville
Re: [Doepfer_a100] Manual gate with A140 adsr
2016-05-26 by james.husted@mac.com
I would suggest getting a manual pushbutton gate module. Doepfer makes the A-164-1 manual gate module and we (www.synthwerks.com) make a couple of modules that will do this quite easily (the MG-1, FST-1T, or any of our FSR modules) plus give you some other useful functions. That way uoi can use these functions with more than the A-140. Almost all of our modules connect to the internal Doepfer Gate bus (with jumpers on the PCB) so no cable is even needed.
-James
James Husted, Designer, Synthwerks LLC • www.synthwerks.com • james@synthwerks.com • info@synthwerks.com
> On May 26, 2016, at 6:42 AM, jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hello there,
> Cheers from Holland
> Jacco Ville
2016-05-27 by jaccoville@yahoo.com
Hello James,
I have two of these A164-1 modules which I use for general reset/start/stop for my sequencers.
Don't use the internal gatesystem.
Just want a manual hands-on gate for each A140 without having to disturb
the patch or use other modules.
Anyone?
Cheers
Jacco
Re: Manual gate with A140 adsr
Is it possible to use the +12V side of the boardsupply to use as a gate by means of a momentary switch?
Re: [Doepfer_a100] Re: Manual gate with A140 adsr
2016-05-27 by Florian Anwander
Am 27.05.2016 um 10:26 schrieb jaccoville@yahoo.com [Doepfer_a100]:
I'd put two resistors 100k/47k as potentiometer and a 1k resistor in
series to the gate. Like this:
12V
>10k
+------switch------^v^------>Gate
> 47k
Gnd
(I hope the ASCII graphik is readable)
Thank you, I am not sure I understand.
Why potentiometers?
Don't fully understand the schematic.
2016-05-27 by Nicholas Keller
I believe Florian meant "voltage divider" but used the term potentiometer (which is a variable voltage divider)
If you search for "voltage divider with resistors," you will find explanations and calculators
Nick
On Friday, May 27, 2016, jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Why potentiometers?
AW: [Doepfer_a100] Manual gate with A140 adsr
2016-05-30 by yahoo@doepfer.de
> Hello there,
> Cheers from Holland
> Jacco Ville
+12V via a protection resistor (e.g. 1k) is fine. The A-140 does not require exactly +5V. Any voltage beyond about +3V will work.
Best wishes
Dieter Doepfer
