Doepfer
A155 wrong wired from factory
2016-06-24 by jaccoville@yahoo.com
Hello Dieter,
Last year I bought an A155.
It worked very well.
A few days ago I also ordered an A154.
After making the connections fun was over sadly.
I did some investigation (I already have two sets of 155/154 which work fine) and comparison I discovered that the wiring on the A155 is wrong.
Flatcables red stripes are all opposite!
This looks like a misstake made with production.
I notified Thomann for returning the unit.
Hope this will be solved under guarantee.
Or do I have to send it to Doepfer?
Best regards
Jacco Ville
Re: [Doepfer_a100] A155 wrong wired from factory
2016-06-24 by Florian Anwander
Hello Jacco
I assume that this will be a warranty "repair". In fact they only have
to rewire it correctly and send the module back to you.
Dieter will assumingly clear this after his vacation.
Florian
Am 24.06.2016 um 08:32 schrieb jaccoville@yahoo.com [Doepfer_a100]:
> Hello Dieter,
> Best regards
> Jacco Ville
> Posted by: jaccoville@yahoo.com
> Yahoo Groups Links
2016-06-24 by Jacco Ville
Hello Florian,
Thans you for your reply.
I think it's broken.
All leds flashed.
It worked until the a154 came in.
I connected everything with red lines like the a155 was connected, this resulted in damage.
Best regards
Jacco Ville
Verstuurd vanaf mijn iPhone 5 Black OPS Edition
> Op 24 jun. 2016 om 09:32 heeft Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hello Jacco
> Florian
> > Hello Dieter,
> > Best regards
> > Jacco Ville
> > Yahoo Groups Links
Btw
I have pictures of the original wiring of this specific A155
Don't know if I can upload them here.
Jacco Ville
Verstuurd vanaf mijn iPhone SE
> Op 24 jun. 2016 om 10:02 heeft Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hello Florian,
> All leds flashed.
> Best regards
> Jacco Ville
>> Hello Jacco
>> Florian
>> > Hello Dieter,
>> > Best regards
>> > Jacco Ville
>> > Yahoo Groups Links
The pictures come through fine.
Does it still flash when you put it back to the original state?
Can you post pictures with the 155 and 154 connected?
Basically the colour does is not the important part. You should obey the
orientation of the flat-cables.
I will post later a picture of the wiring in my 154/155 combination.
Florian
On 24.06.16 10:11 , Jacco Ville jaccoville@yahoo.com [Doepfer_a100] wrote:
> Btw
> Jacco Ville
> <mailto:jaccoville@yahoo.com> [Doepfer_a100]
> <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>> het
>> Hello Florian,
>> All leds flashed.
>> Best regards
>> Jacco Ville
>> fanwander@mnet-online.de <mailto:fanwander@mnet-online.de>
>> <mailto:Doepfer_a100@yahoogroups.com>> het volgende geschreven:
>>> Hello Jacco
>>> Florian
>>> <mailto:jaccoville@yahoo.com> [Doepfer_a100]:
>>> > Hello Dieter,
>>> wrong.
>>> > Best regards
>>> > Jacco Ville
>>> > Posted by: jaccoville@yahoo.com <mailto:jaccoville@yahoo.com>
>>> > Yahoo Groups Links
Hello Florian,
After this small disaster I checked my other two a155/154 sets so that's where I discovered the wrong wiring.
After that I ignored the red lines and tried again but the a155 only made a few steps before it frooze.
So I am sure something has been blown up.
I ordered a new a155 at Thomann that should arrive this monday.
Sounds must go on and I don't have the patience waiting for weeks.
Cheers
Jacco
Verstuurd vanaf mijn iPhone SE Lunatik
> Op 24 jun. 2016 om 12:40 heeft Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Florian
> > Btw
> > Jacco Ville
> >> Hello Florian,
> >> All leds flashed.
> >> Best regards
> >> Jacco Ville
> >>> Hello Jacco
> >>> Florian
> >>> > Hello Dieter,
> >>> wrong.
> >>> > Best regards
> >>> > Jacco Ville
> >>> > Yahoo Groups Links
AW: [Doepfer_a100] A155 wrong wired from factory
2016-06-29 by yahoo@doepfer.de
That's an obviously wrong wired module ! The red stripe of the ribbon cable connecting the trigger and potentiometer boards to the control board should be the other way round. It has no effect until the A-155 module is running alone (without A-154). But if A-155 and A-154 are connected as prescribed (red wire = red wire) the connection is wrong and the module(s) may be damaged. I'm very sorry about this issue and will instruct our manufacturer to pay attention to the correct position of the red stripe. Please return the module for a new one (or refund) to Thomann. To be on the safe side please return also the A-154. Maybe it has been damaged also.
For all members: please check if the cable orientation is correct (i.e. not as in the pictures below). We will offer a free replacement for all modules wired in the wrong way.
Note: it causes a problem only if the A-155 is connected to an A-154. As long as the A-155 runs alone no problems will occur.
Best wishes
Dieter Doepfer
  -----Ursprüngliche Nachricht-----
  Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
  Gesendet: Freitag, 24. Juni 2016 10:11
  An: Doepfer_a100@yahoogroups.com
  Betreff: Re: [Doepfer_a100] A155 wrong wired from factory
  Btw
  Jacco Ville
    Hello Florian,
    All leds flashed.
    Best regards
    Jacco Ville
      Hello Jacco
      Florian
      > Hello Dieter,
      > Best regards
      > Jacco Ville
      > Yahoo Groups Links
Re: AW: [Doepfer_a100] A155 wrong wired from factory
2016-06-29 by Jacco Ville
Hello Dieter,
I already sent the A155 back to Thomann with a small note attached.
No conformation received yet.
The A154 seems fine, I hope.
It didn't flash (and popped) like the A155.
I have to check it.
I'm glad things will be solved.
Thank you for your reply.
Best regards
Jacco Ville
> Op 29 jun. 2016 om 12:23 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Best wishes
> Dieter Doepfer
> Btw
> Jacco Ville
> Hello Florian,
> All leds flashed.
> Best regards
> Jacco Ville
> Hello Jacco
> Florian
> > Hello Dieter,
> > Best regards
> > Jacco Ville
> > Yahoo Groups Links
2016-07-01 by Jacco Ville
Update
Today I received another new A155 (ordered separately, not the one under guarantee) and coupled it with the A154 which made me happy to see all worked fine.
The "bad" A155 has arrived at Thomann service center.
Have a nice weekend
Jacco Ville
> Op 29 jun. 2016 om 12:55 heeft Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hello Dieter,
> I have to check it.
> Best regards
> Jacco Ville
>> Best wishes
>> Dieter Doepfer
>> Btw
>> Jacco Ville
>> Hello Florian,
>> All leds flashed.
>> Best regards
>> Jacco Ville
>> Hello Jacco
>> Florian
>> > Hello Dieter,
>> > Best regards
>> > Jacco Ville
>> > Yahoo Groups Links
AW: AW: [Doepfer_a100] A155 wrong wired from factory
2016-07-04 by yahoo@doepfer.de
> Update
> Have a nice weekend
> Jacco Ville
I'm glad to hear that the problems have been solved.
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] A155 wrong wired from factory
2016-07-08 by Jacco Ville
Update
Seems the A155 is sent to Doepfer.
Best regards
Jacco Ville
Op 4 jul. 2016 om 09:39 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
>> Update
>> Have a nice weekend
>> Jacco Ville
> Best wishes
> Dieter Doepfer
> Yahoo Groups Links
2016-07-11 by Jacco Ville
Update
....and yes, a new A155 is on its way to Holland :-)
Good service from Doepfer and Thomann
Best regards
Jacco Ville
> Op 8 jul. 2016 om 14:44 heeft Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Update
> Best regards
> Jacco Ville
> >> Update
> >> Have a nice weekend
> >> Jacco Ville
> > Best wishes
> > Dieter Doepfer
> > Yahoo Groups Links
