Doepfer
a111( high end vco with 3340) issue
2016-09-26 by ventrality@gmail.com
hi friends
Yesterday my dear A111 stopped to work..., perhaps (i m not totally sure) it was damaged by a wrong voltaje supplied by my doepfer bus-Access module, which had a intermitent failure due to a defective bus ribbon cable..( i know i don t need to use the cv input because my bus board has the jumpers inside!)
Where should I check ? Maybe CEM is dead?
Maaaany thanks to everyone!!
Kind regards from Spain
Miguel
AW: [Doepfer_a100] a111( high end vco with 3340) issue
2016-09-26 by yahoo@doepfer.de
From the distance it's impossible to find out what's wrong. But the A-111
cannot be damaged by a "wrong" CV coming from the bus access module. It will
withstand any CV in the range -12V...+12V and the bus access module cannot
generate a voltage beyond these values. If you cannot find the fault please
follow the repair notes on the FAQ page of our website:
www.doepfer.com > English > FAQ > General > Repair procedure
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Montag, 26. September 2016 09:31
> Betreff: [Doepfer_a100] a111( high end vco with 3340) issue
> hi friends
> Miguel
