Want to buy a A-100 need help
2016-10-09 by michaelhesse10@yahoo.de
Hello
I´am new in this group.
Michael from Germany 50 years old.
I want buy an A-100 System ( 4 rows each 168 TE / HP )
Below a list of modules.
I would be appreciate if you can give me some suggestions (opinion , help )
to complete the system. ( Have 78 TE / HP free space )
some questions:
- I want the mixer 138p because do not want mono ( sound on 1 speaker )
do the mixer work with both signals CV and audio ?
- I have 2 A-140 ADSR do I need one or two more ?
- I have 2 A-180-1 multiple an 1 A-182 switch multiple thats enough ?
Further I think about follow moduls ?
A-101 Vetrol light
A-190-5 Polyphonic
A-149-1 Buchla
A-152 Adress TH
A-104 Trautorium + A-113 Subharmonic
( can this moduls make sound like female vocal chors )
A-107 Morphing
A-105
24dB Low Pass (SSM Type)
A-106-6
XP VCF
A-108
48dB Low Pass
A-110-1
Standard VCO
2x
A-111-2
High-End-VCO II (~ spring 2016)
A-114
Ringmodulator
A-115
Audio Divider
A-116
VC Wave Shaper
A-117
Digital Noise / 808 Sound Source
A-118
Analog Noise / Random Voltage
A-120
24dB Low Pass (Moog type)
A-124
Wasp Multimode Filter
A-125
Voltage Controller Phaser (VCP)
A-127
Triple Resonance VCF
A-128
Fixed Filter Bank
A-134
Panning
A-130
VCA linear
A-131
VCA exponential
A-136
Distortion/Waveshape
A-138 p
Mixer
2X
A-138 o
Mixer
A-140
ADSR
2x
A-142-1
VC Decay/Gate
A-144
Morphing Controller
A-145
Standard LFO
2 x
A-146
Variable Waveform LFO
A-147-2
Voltage Controlled Delayed LFO
A-148
Dual Sample&Hold
A-150
Dual Voltage Controlled Switch
A-151
Quad Sequential Switch
A-154
Enhanced Sequencer Controller
A-155
Analog/Trigger Sequencer
2x
A-157
Trigger Sequencer System (A-157-1/2/3)
A-157-2
A-157-3
A-160-1
Clock Divider
A-160-5
Clock Multiplier/Ratcheting Controller
2x
A-161
Clock Sequencer
A-162
Dual Trigger Delay
A-163
Voltage Controlled Divider
A-170
Slew Limiter
A-175
Dual Voltage Inverter
A-180-1
Multiple I (4HP)
2x
A-182
Switched Multiple
A-187-1
DSP Effects Module
A-190-4
MIDI-to-CV/Gate/Clock Interface
A-199
Spring Reverb
Thank you
Michael
