Doepfer
A160-5 latency
A160-5 latency
2016-10-17 by jaccoville@yahoo.com
Hello Doepfer users,
When setting up a patch with my A160-5 clockdivider I noticed that when I send a CV to the multiplier input for creating ratcheting there is a latency of one sequencer step.
To be clear: I made the patch classic.
See example in the manual.
So one A155.
The point is that I have to set the CV step on sequencer step, let's say, 7 to get the ratcheting effect on step 8 in the sequence.
Is this normal?
Best regards
Jacco Ville
Re: [Doepfer_a100] A160-5 latency
2016-10-17 by achtung_999
This is stated in the manual. And if you think about it, it makes sense doesn't it?
There are no electronics yet, that have psychic powers ;-)
Ernst
On Mon, Oct 17, 2016 at 9:02 PM, jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
So one A155.
Is this normal?
Best regards
Jacco Ville
2016-10-17 by Jacco Ville
Well for me this note in the manual is about the clock input which has to be stable and infact it is in this setup.
Only the CV input is getting a voltage which fluctuates to get the ratcheting    effect.
Jacco
> Op 17 okt. 2016 om 23:06 heeft achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Ernst
>> So one A155.
>> Is this normal?
>> Best regards
>> Jacco Ville
AW: [Doepfer_a100] A160-5 latency
2016-10-18 by yahoo@doepfer.de
> So one A155.
> Is this normal?
> Best regards
> Jacco Ville
I just used the A-160-5 for a performance in Munic (DigitalAnalog Festival)
and cannot confirm this behaviour. You should use the pre output of the
A-155 to avoid any delay. If this does not help please contact Christian
Assall (software@doepfer.de). He programmed the A-160-5 firmware together
with the A-155.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] A160-5 latency
2016-10-18 by Jacco Ville
Hello Dieter,
I made the patch exactly by the book.
To be sure I made it once again.
What I notice is that once the CV from the A155 sends a voltage the A160-5 does shows this by increasing the leds BUT the actual ratcheting of the notes to my A140 adsr follows AFTER the CV has passed, so the next note makes the ratcheting sequence.
For me it seems not logical.
There is always a steady masterclock to the "clock in" of the A160-5.
Best regards
Jacco Ville
Op 18 okt. 2016 om 09:09 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
>> So one A155.
>> Is this normal?
>> Best regards
>> Jacco Ville
> with the A-155.
> Best wishes
> Dieter Doepfer
> Yahoo Groups Links
2016-10-18 by Florian Anwander
Hello Jacco,
just think twice:
The voltage which sets the division/multiplication factor, comes
slightly after the clock-tick, that should be multiplied. So the
multiplying/dividing will happen for the next clock tick. Why comes the
Voltage after the clocktick? Because there is a minimal delay within the
A-155. There are rise times in the 4051 and in the address dividers,
which do the sequencing in the A-155. These are in the range of
nanoseconds. But this is enugh to be "to late".
So yes: I think it is normal that the CV will set the multiplication
factor for the NEXT step.
Florian
On 18.10.16 09:47 , Jacco Ville jaccoville@yahoo.com [Doepfer_a100] wrote:
> Hello Dieter,
> Best regards
> Jacco Ville
> Op 18 okt. 2016 om 09:09 heeft yahoo@doepfer.de [Doepfer_a100]<Doepfer_a100@yahoogroups.com>  het volgende geschreven:
>>> So one A155.
>>> Is this normal?
>>> Best regards
>>> Jacco Ville
>> with the A-155.
>> Best wishes
>> Dieter Doepfer
>> Yahoo Groups Links
> Posted by: Jacco Ville<jaccoville@yahoo.com>
> Yahoo Groups Links
Hello Florian,
Thank you for your clear explaination.
I like the A160-5 to use but I have to have to attention to place the CV one step ahead which isn't a big deal.
Now I know why
Thanks again
Jacco
> Op 18 okt. 2016 om 10:57 heeft Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hello Jacco,
> just think twice:
> Florian
> > Hello Dieter,
> > Best regards
> > Jacco Ville
> >>> So one A155.
> >>> Is this normal?
> >>> Best regards
> >>> Jacco Ville
> >> with the A-155.
> >> Best wishes
> >> Dieter Doepfer
> >> Yahoo Groups Links
> > Yahoo Groups Links
2016-10-18 by achtung_999
Ah yes! Of course, sorry Jacco I did not read your message correctly.
Ernst
On Mon, Oct 17, 2016 at 11:26 PM, Jacco Ville jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Jacco
Ernst
So one A155.
Is this normal?
Best regards
Jacco Ville
2016-10-18 by jaccoville@yahoo.com
And in the end it is a faulty microprocessor.
I contacted Doepfer about this and they confirmed.
Change of processor and go!
Cheers
Jacco
2016-10-22 by jaccoville@yahoo.com
Hi there all,
After having mail contact with Chris from Doepfer who offerd excellent service to take care of a new processor I couldn't resist also order a new A160-5 at Thomann.
Once installed in my system it worked like a charm, no latency issues or whatsoever.
Thank you again Chris for your help with this and with sending me the long
awaited update software for my A157's.
Cheers
Jacco Ville
The Netherlands
2016-10-22 by Jonathan
Doesvthat mean there are lots of faulty microprocessors? I just assumed the one step latency was expected as stabilisation time for the mutiplication routine. Is mine faulty too?
Jonathan Shapero
From my iPad Air
> On 22 Oct 2016, at 08:51, jaccoville@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hi there all,
> Cheers
> Jacco Ville
> The Netherlands
2016-10-22 by Jacco Ville
Hello Jonathan,
There should be no latency....
So I recommand to contact Chris about this.
No worries, very correct and friendly service.
Just swapping the processor and your good to go.
Best regards
Jacco Ville
> Op 22 okt. 2016 om 16:54 heeft Jonathan jss9h@aol.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Jonathan Shapero
> From my iPad Air
>> Hi there all,
>> Cheers
>> Jacco Ville
>> The Netherlands
2016-10-22 by achtung_999
Jonathan, you are like me before in this thread, mistaking the bit about the steady clock with the problem that Jacco was experiencing.
Ernst
On Sat, Oct 22, 2016 at 4:54 PM, Jonathan jss9h@aol.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
Jonathan Shapero
From my iPad Air
Hi there all,
Cheers
Jacco Ville
The Netherlands
2016-10-23 by Jacco Ville
Hi Jonathan,
If that is the matter what Ernst said.
Your (masterclock) has to be steady, at a sudden tempo change the A160-5 will need a few pulses to adapt.
However, this shouldn't be the point with the multiplier/ratcheting function. When sending different CV to the CV input it has to spit out the multiplied pulses direct and with no delay, so spot on.
The last thing didn't happen with my A160-5 so that was where the faulty processor showed up.
Make the basic patch like described in the manual and you'll notice right away.
Best regards
Jacco Ville
> Op 23 okt. 2016 om 01:40 heeft achtung_999 heinrich.himmelwasser@gmail.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Ernst
>> Jonathan Shapero
>> From my iPad Air
>>> Hi there all,
>>> Cheers
>>> Jacco Ville
>>> The Netherlands
