Doepfer
A-110 fail!
A-110 fail!
2016-12-21 by jbragg@fernforest.co.uk
I was adding modules into a new Waldorf KB37 which does seem excellent.
For some reason I got confused with which way round the power cables went - I think because I had a mix of Doepfer and non-Doepfer modules, and some seem to require a twisted cable.
So plugged in an A-110 with a twist in the cable - followed by an odd smell, and now it doesn't work!
What have I most likely done to it, and is it easily repairable!
Oddly a second A-110 didn't work properly either way, but is fine back in the Doepfer case, but a A-111 vco2 is fine in the new Waldorf case.
love
JamieB
Re: [Doepfer_a100] A-110 fail!
2016-12-21 by Florian Anwander
Hi
It is difficult to tell. Assumingly one of the two voltage regulators:
IC5 (looks like a power transistor) or IC4 (looks like a transistor).
See http://www.doepfer.de/a110_tec.htm
I'd plug the  module in again and would test with the tip of my finger,
which IC gets hot...
Florian
