Doepfer
A138P versions
A138P versions
2017-06-06 by jaccoville@yahoo.com
Hello Dieter,
Today I finally received my 3  ordered A138P's from Thomann.
What modifications have been made?
Two of batch 4-17 have some extra jumpers and an extra connector.
One of batch 11-16 hasn't.
Mit freundlichen Grüßen
Jacco Ville
AW: [Doepfer_a100] A138P versions
2017-06-06 by yahoo@doepfer.de
Hello Jacco,
the new A-138p are equipped with an additional pin header that can be used
to connect internally the quad envelope follower A-135-4C so that the four
audio input signals of the A-138p can be used as default inputs for the
A-135-4C. It's the pin header JP1 and is labelled "DEFAULT INPUTS TO
ENVELOPE FOLLOWER OPTION". In addition four new jumpers are available to
define if the default signals to A-135-4C are pre/post the level controls of
the A-138p.
I'll add the information to the technical document on our website a.s.a.p.
If you don't use the A-135-4C the additional pin header and jumpers of the
A-138p have no meaning.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Dienstag, 6. Juni 2017 16:00
> Betreff: [Doepfer_a100] A138P versions
> Hello Dieter,
> Jacco Ville
> Posted by: jaccoville@yahoo.com
> Yahoo Groups Links
Re: AW: [Doepfer_a100] A138P versions
2017-06-06 by Jacco Ville
Hello Dieter,
Thank you for your reply.
Then I'll return this older version, besides the difference in jumpers the GAIN pots/knobs are also lower than the new version.
Cosmetically not very nice.
Guess Thomann sendet me some old stock.
Cheers
Jacco Ville
Sent from my IPhone.
> Op 6 jun. 2017 om 17:05 heeft yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> Hello Jacco,
> the A-138p.
> Best wishes
> Dieter Doepfer
>> Hello Dieter,
>> Jacco Ville
>> Yahoo Groups Links
> Yahoo Groups Links
Re: A138P versions
2017-11-15 by vclab@protonmail.com
wooh! i have an A-138p Vintage Edition!
can all vintage editions accept A-135-4C ??
or i should research before ordering the later?
got confused with this one
AW: [Doepfer_a100] Re: A138P versions
2017-11-15 by yahoo@doepfer.de
As the A-135-4C envelope follower was designed about one year after the
A-138p the first pcb version of the A-138p does not have an internal
connector for the A-135-4C. Only the second version of the A-138p
(manufactured from about June 2017) is equipped with the additional
connector JP1 (labelled "TO ENVELOPE FOLLOWER OPTION"). The pc boards are
marked "A-138p PERFORMANCE MIXER VERSION 2". The dot near to JP1 denotes the
red wire of the ribbon cable which is used to establish the connection to
A-135-4C. You have to look at the pc board to find out which version you
own. It has nothing to do with vintage or standard, just with the pc board
because both (vintage and standard) are have been manufactured in the old
and new version. It depends upon the period of storage of the dealer in
question which they have for sale.
Best wishes
Dieter Doepfer
