Doepfer
A-190-5 question
A-190-5 question
2017-10-23 by Neil Kagan
Hi Dieter,
Can I ask if the A-190-5 midi to cv resolution will be higher than the 190-4? I only ask as I do notice that this ‘stepping’ is noticeable when controlled from software or keyboards with say aftertouch.
Neil
AW: [Doepfer_a100] A-190-5 question
2017-10-23 by yahoo@doepfer.de
Hello Neil,
the A-190-5 will not have a higher resolution. But I'm not sure if it's
indeed a problem of the CV resolution. 12 bit should be more than enough
because the midi data for monophonic after touch are 7 bit only. I suppose
that it's a problem with the data rate (i.e. how fast the data is sent). The
A-190-4 does not have a "software slew limiter" which smoothes the stepped
data.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Montag, 23. Oktober 2017 13:11
> Betreff: [Doepfer_a100] A-190-5 question
> Hi Dieter,
> aftertouch.
> Regards,
> Neil
Re: AW: [Doepfer_a100] A-190-5 question
Thanks for responding so quickly Dieter, one final question: Is there any way to transmit midi clock via the 190-5?
Neil
> On 23 Oct 2017, at 12:24, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hello Neil,
> data.
> Best wishes
> Dieter Doepfer
>> Hi Dieter,
>> aftertouch.
>> Regards,
>> Neil
> Yahoo Groups Links
AW: AW: [Doepfer_a100] A-190-5 question
I'm sorry - no. The A-190-5 is polyphonic USB/Midi-to-CV/Gate interface to
convert note on/off messages on one or more Midi channels into CV and Gate
signals. For the conversion of Midi clock I'd recommend the A-190-8 as it
offers the most possibilities. Maybe one of the gate outputs of the A-190-5
may work as clock outputs in a future firmware version. But I do not want to
promise anything before Christian confirms that this a potential option.
Best wishes
Dieter Doepfer
> Gesendet: Montag, 23. Oktober 2017 13:29
> Betreff: Re: AW: [Doepfer_a100] A-190-5 question
> Neil
> Sent from my iPhone
> > Hello Neil,
> only. I suppose
> is sent). The
> the stepped
> > data.
> > Best wishes
> > Dieter Doepfer
> >> Hi Dieter,
> >> aftertouch.
> >> Regards,
> >> Neil
> > Yahoo Groups Links
> Posted by: Neil Kagan <nkagan@mac.com>
> Yahoo Groups Links
Re: AW: AW: [Doepfer_a100] A-190-5 question
Thanks again Dieter!
Neil
> On 23 Oct 2017, at 13:48, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Best wishes
> Dieter Doepfer
>> Neil
>> Sent from my iPhone
>>> Hello Neil,
>> only. I suppose
>> is sent). The
>> the stepped
>>> data.
>>> Best wishes
>>> Dieter Doepfer
>>>> Hi Dieter,
>>>> aftertouch.
>>>> Regards,
>>>> Neil
>>> Yahoo Groups Links
>> Yahoo Groups Links
> Yahoo Groups Links
