Repackaging the A-112 for modern/shallow cases
2017-10-14 by brandon zeeb
Greetings everyone.
Long time A-112 lover here, looking to make it fit in a case with depth of 50-60mm or less. Has anyone considered or successfully modified their A-112 to fit within one of these cases? If so, any lessons learned you're able to share, or general tips for doing this kind of modification?
I'm considering re-mounting the panel controls to a different PCB and running leads back to the main PCB, which seems simple enough. However, finding a way to support the original PCB looks to be tricky, as there aren't any holes for spacers of places where they could be added. One thing that comes to mind is re-mounting it within a project box and hook and loop fastening that to the back of my case.
Any guidance offered is much appreciated. Since crossgrading to Intellijel cases from P9s I haven't been able to use the A-112 which leaves me with many tears :'(
Cheers!
Brandon Zeeb
