Doepfer
Suggestion: Simple+cheap multiple MIDI CC to CV converter
2017-09-22 by Ville Oikarinen
Hello.
I have a module suggestion: a simple cheap module that converts
multiple MIDI control change messages into multiple control voltages.
AFAIK, the simple and cheap MIDI-CV converters (like A-190-4) don't
support many CCs, only velocity + one controller. Only expensive
converters support multiple CCs.
I don't understand electronics, but I guess it wouldn't cost too much
to just skip note ons and concentrate on a set of CCs and output them
as voltages. To keep costs down, the MIDI channel and controller
numbers could be hard-coded. This way no user interface would be
needed.
Or, if it doesn't cost much, maybe a switch for MIDI channel can be
added. But the controllers can be any predefined set, because
computers and their software can easily accommodate to that.
Maybe it would be nice to support both 7 and 14 bit controllers, but
if not, 14 bits would be better, for accuracy of the values rather
than speed of change.
If anybody, Doepfer would be the company to achieve this, right? :)
- Ville Oikarinen
Re: [Doepfer_a100] Suggestion: Simple+cheap multiple MIDI CC to CV converter
2017-09-22 by Bakis Sirros
hi,
such a module existed (A191 Midi to CV), but has now been discontinued.
 i have it in my Doepfer system and it is very nice for the midi cc's to cv conversion and for the nice Shepard tone generation.
best regards,Bakis.
      From: "Ville Oikarinen ville@oikarinen.org [Doepfer_a100]" <Doepfer_a100@yahoogroups.com>
 Sent: Friday, September 22, 2017 2:09 PM
 Subject: [Doepfer_a100] Suggestion: Simple+cheap multiple MIDI CC to CV converter
    Hello.
needed.
- Ville Oikarinen
AW: [Doepfer_a100] Suggestion: Simple+cheap multiple MIDI CC to CV converter
2017-09-22 by yahoo@doepfer.de
We have such a device available as a DIY product (MTV16) but not as module.
It's easy for a DIYer to mount the MTV16 board behind a front panel with 16
sockets and wire the 16 sockets to the MTV16. And the MTV16 could be powered
by the +12V of the A-100 bus. I'm not sure if there are sufficient inquiries
to justify the "conversion" of the MTV16 into a module.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Freitag, 22. September 2017 12:41
> Betreff: [Doepfer_a100] Suggestion: Simple+cheap multiple MIDI CC to CV
> converter
> Hello.
> needed.
> - Ville Oikarinen
> Posted by: Ville Oikarinen <ville@oikarinen.org>
> Yahoo Groups Links
Re: AW: [Doepfer_a100] Suggestion: Simple+cheap multiple MIDI CC to CV converter
2017-09-22 by Malte Stamm-Gadow
Hello Dieter,
I think, there are many musicians like me out there, who will like a modul to convert Midi-CCs into CV and who are no diy-guys.
Greetings,
Malte
Malte Stamm-Gadow
Diekmissen 5
24159 Kiel
> Am 22.09.2017 um 13:53 schrieb yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com>:
> Best wishes
> Dieter Doepfer
>> converter
>> Hello.
>> needed.
>> - Ville Oikarinen
>> Yahoo Groups Links
> Yahoo Groups Links
2017-09-22 by Diego Ragnini
Me too once I believed this way, though frankly it seems that modular synthesis fellows usually keep themselves far away from the MIDI world… it shouldn’t be too hard to find someone available for mounting it for you. I ignored the existence of the MTV16 and might be interested in having one (assembled) for me !
Best, Diego
> Il giorno 22 set 2017, alle ore 14:01, Malte Stamm-Gadow m.stamm-gadow@innamorati.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Hello Dieter,
> Greetings,
> Malte
> Malte Stamm-Gadow
> Diekmissen 5
> 24159 Kiel
> Am 22.09.2017 um 13:53 schrieb yahoo@doepfer.de <mailto:yahoo@doepfer.de> [Doepfer_a100] <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>>:
>> Best wishes
>> Dieter Doepfer
>>> Von: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com> [mailto:Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>]
>>> An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>
>>> converter
>>> Hello.
>>> needed.
>>> - Ville Oikarinen
>>> Posted by: Ville Oikarinen <ville@oikarinen.org <mailto:ville@oikarinen.org>>
>>> Yahoo Groups Links
>> Yahoo Groups Links
Thanks, Dieter. The features look promising.
Well, I was inaccurate in my request: I don't really care if it's a
module or a separate device. Maybe separate is even better so it
doesn't take any rack space.
I'm not skilled with electronics myself, but since this is a DIY
product, it shouldn't be too difficult for experts (at Doepfer or
somebody else) to walk the last mile and productize this. So not only
a board with pins, but a box with 3.5mm CV outs and a power in so
somebody like me could use it without soldering anything.
- Ville Oikarinen
2017-09-22 by Florian Anwander
Hi
Am 22.09.2017 um 13:53 schrieb yahoo@doepfer.de [Doepfer_a100]:
I think that there is a reason, why the A-191 did not sell well. And
also there is a reason why for example Schneidersladen lists 76
interface modules, but non of them is a MIDI-CC to CV interface. Mostly
the 7Bit resolution of MIDI is too coarse and the transfer rate if MIDI
is too slow. The Silentway / Expert Sleepers system provides 24Bit and
control signal in the full audio range. This really great system, which
is well established in the DAW-world, will always cut the sales of any
Florian
Yes, you are of course right that MIDI has sever limitations. Still,
there are a lot of usecases where those limitations don't matter or
the are even desirable. (Most limitations tend to create new styles in
art.)
Also, the audio to CV solutions have quite poor linux/OSS support at
the moment, AFAIK.
So, if the price is right, MIDI2CV still has its uses, IMO.
- Ville Oikarinen
Useful observations, didn’t know about the 7bit, thought from MIDI to CV it’s 12bit by default.
Then there’s no room left for both efficient and cheap tools, as demanded in the first post (if I am not wrong believing that Expert Sleepers means money…)
> Il giorno 22 set 2017, alle ore 14:35, Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Hi
> Florian
> Yahoo Groups Links
Midi data is 7 bits. But certain controllers send two 7-bit bytes so
their resolution is 14 bits. This means that the values cannot be
changed so often, because they require more bandwidth.
Sure, MIDI can never be as "efficient" as digital audio, but it's OK.
I just want the "cheap" part, within limitations of the MIDI standard.
- Ville Oikarinen
> Don't tell me that your Doepfer system did not mean money for you :-))))
Also, it seems ES-3 isn't even terribly expensive. It's just that I'm
not sure I'll be able to use it from my linux machine, with the
software and connections I have. Of course I'd be happy to be
corrected here.
- Ville Oikarinen
LOL !
No I don’t tell you :-)
But here Ville was asking for cheap stuff
I have to deepen ES systems though for live applications it would entail to take always an audio interface with multiple outs on stage… :-(
Il giorno 22 set 2017, alle ore 14:57, Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
Hi Diego
Florian
Ville, I think you're right and hope ES is not too expensive, I admit to have replied without verify anything about costs, I simply remembered that there are different modules though likely are needed to make the inverse process (from mod sys to the DAW recorder) or probably also to "manage" the recorded tracks when come back to the mod system...?
In case the software is enough to send cv to the modular sys through an audio interface then I would start to use it asap
Thanks for having started this topic
Best, dxx
Inviato da iPad
> Il giorno 22 set 2017, alle ore 15:01, Ville Oikarinen ville@oikarinen.org [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> corrected here.
> - Ville Oikarinen
Re: Suggestion: Simple+cheap multiple MIDI CC to CV converter
2017-10-16 by Ville Oikarinen
I found another option: https://waldorfmusic.com/en/kb37
If you only need Midi CC->CV, it's not cheap, but it not only
transforms 3 user-defined CCs into CV, it's also a MIDI+CV keyboard,
modular rack, headphone amp etc.
- Ville Oikarinen
