Doepfer
A-132-4 Input Signal Level
2018-01-09 by John Hollis
I find it is necessary to greatly attenuate a VCO output (say the sine wave from a A-111-1) to prevent distortion. I have adjusted the trimmers to get a full range sweep for an ADSR.
Is there an input resistor that could be changed to remove the need for 2 x A-183-1 dual attenuators, or am I thinking about this incorrectly?
Thanks
John
AW: [Doepfer_a100] A-132-4 Input Signal Level
2018-01-09 by yahoo@doepfer.de
Hello,
each of the four VCAs is equipped with a 47k input resistor (R1, R12, R23,
R34). If you increase the values of these resistors (or add a trimming
potentiometer to each resistor) the input signal is attenuated. You find the
position of the resistors in the attached picture.
Best wishes
Dieter Doepfer
> -----Ursprungliche Nachricht-----
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Dienstag, 9. Januar 2018 12:50
> An: yahoo@doepfer.de [Doepfer_a100]
> Betreff: [Doepfer_a100] A-132-4 Input Signal Level
> this incorrectly?
> Thanks
> John
> Posted by: John Hollis <john@hollis.je>
> Yahoo Groups Links
Re: AW: [Doepfer_a100] A-132-4 Input Signal Level
2018-01-09 by Bakis Sirros
attachments on the group emails are not allowed.
maybe upload the photo in the files/photos section of the group ?
      From: "yahoo@doepfer.de [Doepfer_a100]" <Doepfer_a100@yahoogroups.com>
Cc: john@hollis.je
 Sent: Tuesday, January 9, 2018 2:34 PM
 Subject: AW: [Doepfer_a100] A-132-4 Input Signal Level
    Hello,
Best wishes
Dieter Doepfer
> this incorrectly?
> Thanks
> John
> Yahoo Groups Links
AW: AW: [Doepfer_a100] A-132-4 Input Signal Level
That's why I've sent a CC to John's email address directly.
Best wishes
Dieter Doepfer
> Gesendet: Dienstag, 9. Januar 2018 13:47
> Betreff: Re: AW: [Doepfer_a100] A-132-4 Input Signal Level
> Cc: john@hollis.je
> Hello,
> You find the
> Best wishes
> Dieter Doepfer
> > this incorrectly?
> > Thanks
> > John
> > Yahoo Groups Links
Re: [Doepfer_a100] A-132-4 Input Signal Level
Hi Dieter,
Thanks for the PCB layout. I needed 2M2 to get it clean! I guess it’s looking into a fairly high impedance.
The results are great. My Simmonds SDSV patch now sounds perfectly 1981.
Best wishes,
John
> On 9 Jan 2018, at 12:30, <yahoo@doepfer.de> <yahoo@doepfer.de> wrote:
> Hello,
> Best wishes
> Dieter Doepfer
>> this incorrectly?
>> Thanks
>> John
>> Yahoo Groups Links
> <A132_4_b.gif>
2018-01-09 by christian ienni
heh, i remember someone in a Keyboard magazine from ~35ish years ago describing it as "that Simmons sheep-kicked-in-the-gut drum sound".
      From: "John Hollis john@hollis.co.uk [Doepfer_a100]" <Doepfer_a100@yahoogroups.com>
 To: yahoo@doepfer.de
Cc: Doepfer_a100@yahoogroups.com
 Sent: Tuesday, January 9, 2018 8:16 AM
 Subject: Re: [Doepfer_a100] A-132-4 Input Signal Level
    Hi Dieter,
Best wishes,
John
If only voltage controlled sheep were rack mountable…
> On 9 Jan 2018, at 19:23, christian ienni ienni23@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> From: "John Hollis john@hollis.co.uk <mailto:john@hollis.co.uk> [Doepfer_a100]" <Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>>
> To: yahoo@doepfer.de <mailto:yahoo@doepfer.de>
> Cc: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100@yahoogroups.com>
> Hi Dieter,
> Best wishes,
> John
