> Hi Michael, and the rest of the community.
> This may be just a weird coincidence but I have noticed the exact
> same issue on my A-190-4 today and I was just about the ask the
> community the same question. I do not have a scope so I'm unable
> to verify the value being sent to the VCO from the A-190, but
> just like yours Michael, it is locked to one note no matter what
> CV signal is sent from my keyboard or DAW.
> The gate signal is working correctly.
> This is true whether I connect via the midi connector directly
> from my keyboard or via USB from my DAW.
> This is also true if I send CV to the VCO via CV1 Output on the
> A-190 instead of via the system bus.
> An external sequencer (korg sq-1) sending CV signal directly to
> the VCO works fine, so no issues with my VCOs.
> Final point, when I power on my case with the USB connected to my
> DAW the interface on the A-190 is frozen and I cannot scroll
> through menus. If I power down my case, unplug the USB cable and
> power up again I can access the menus.
> So I have the same question for the community - anything I can
> check before I also contact Thomann.
> Cheers,
> Colum
> On Sun, Jan 7, 2018 at 3:20 PM,
superdarktime@yahoo.com
> [Doepfer_a100] <
Doepfer_a100@yahoogroups.com> wrote:
> Hi,
> My A-190-3 MIDI module has apparently failed on the CV output. On
> my 'scope it shows -5v constant and there is no variation in the
> note pitch when connected to V/octave socket on any of my
> oscillators. I drive it from my MAQ 16/3 and I've checked the
> MIDI out on that with a Kenton Control Freak SE in its MIDI
> analyser mode and that is perfect.
> The gate output of the A-190-3 is operating perfectly.
> My question is, is there anything I can check before sending it
> back to Thomann as it is still under warranty?
> Regards,
> Michael.
