Doepfer
Re: Re: AW: [Doepfer_a100] Further info on the forthcoming A100 modules
2018-03-23 by blacet@blacet.com
On the 143-2, are the EOA, EOD and EOR signals brief pulses or do they
stay high until the module is gated again or ....? The Manual page is
just a repeat of the product description. Thanks -------- Original
Message ---------- A voltage controlled version of the A143-2 would be
amazing, especially if it had individual linear/expo switches for each
of the envelopes and retained the EOA, EOD and EOR outs. In fact a
voltage controlled version of the A143-1 would also be good! On
Monday, March 5, 2018, 10:33:53 AM GMT, yahoo@doepfer.de
[Doepfer_a100] Doepfer_a100@yahoogroups.com wrote: I'm pretty sure
that is the intention, four independent ADSRs with a singular set of
controls like most polysynths. But I too am curious how the CVins will
work. Seems like they would have to to be applied to all four
envelopes at the same time and by the same amount. So you could not
create four separate and different ADSRs and, as an example, play a
chord with velocity to Release and affect each note uniquely. For
that, one would still require separate VCADSR modules. The module is
planned for polyphonic applications with the same value of each
parameters for all envelopes. The control inputs of all ADSRs are
internally connected. But for DIYers it would be possi ble to
interrupt the internal connections and use separate CVs for each ADSR.
But this would require additional elements at the front panel so that
the advantage of the small 8 HP panel would be lost. We think of more
new ADSRs (like the A-140-2) and maybe we will also design another
Quad VCADSR with such additional features, e.g. master controls plus
individual "variation" inputs for each single ADSR (but not behind a
8HP panel and at a clearly higher price). Even a voltage controlled
version of the A-143-2 is under discussion. Best wishes Dieter Doepfer
---------------------------------- -- Yahoo Groups Links * To visit
your group on the web, go to:
http://groups.yahoo.com/group/Doepfer_a100/ [1] * Your email settings:
Individual Email | Traditional * To change settings online go to:
http://groups.yahoo.com/group/Doepfer_a100/join [2] (Yahoo! ID
required) * To change settings via email:
Doepfer_a100-digest@yahoogroups.com [3]
Doepfer_a100-fullfeatured@yahoogroups.com [4] * To unsubscribe from
this group, send an email to: Doepfer_a100-unsubscribe@yahoogroups.com
[5] * Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/ [6]
Links:
[1] http://groups.yahoo.com/group/Doepfer_a100/
[2] http://groups.yahoo.com/group/Doepfer_a100/join
[3] mailto:Doepfer_a100-digest@yahoogroups.com
[4] mailto:Doepfer_a100-fullfeatured@yahoogroups.com
[5] mailto:Doepfer_a100-unsubscribe@yahoogroups.com
[6] https://info.yahoo.com/legal/us/yahoo/utos/terms/
[7]
https://groups.yahoo.com/neo/groups/Doepfer_a100/conversations/messages/27856;_ylc=X3oDMTJxYXF2dm5vBF9TAzk3MzU5NzE0BGdycElkAzMxODM3MDYEZ3Jwc3BJZAMxNzA1MDMyMTQ0BG1zZ0lkAzI3ODU2BHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTUyMTgxMTI3Mw--?act=reply&messageNum=27856
[8]
mailto:ross_anderton@yahoo.com?subject=Re%3A%20AW%3A%20%5BDoepfer_a100%5D%20Further%20info%20on%20the%20forthcoming%20A100%20modules
[9]
mailto:Doepfer_a100@yahoogroups.com?subject=Re%3A%20AW%3A%20%5BDoepfer_a100%5D%20Further%20info%20on%20the%20forthcoming%20A100%20modules
[10]
https://groups.yahoo.com/neo/groups/Doepfer_a100/conversations/newtopic;_ylc=X3oDMTJlaDJubzRwBF9TAzk3MzU5NzE0BGdycElkAzMxODM3MDYEZ3Jwc3BJZAMxNzA1MDMyMTQ0BHNlYwNmdHIEc2xrA250cGMEc3RpbWUDMTUyMTgxMTI3Mw--
[11]
https://groups.yahoo.com/neo/groups/Doepfer_a100/conversations/topics/27834;_ylc=X3oDMTM2ajFuMGprBF9TAzk3MzU5NzE0BGdycElkAzMxODM3MDYEZ3Jwc3BJZAMxNzA1MDMyMTQ0BG1zZ0lkAzI3ODU2BHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTUyMTgxMTI3MwR0cGNJZAMyNzgzNA--
[12] https://yho.com/1wwmgg
[13]
https://groups.yahoo.com/neo/groups/Doepfer_a100/info;_ylc=X3oDMTJlb3FkcGhvBF9TAzk3MzU5NzE0BGdycElkAzMxODM3MDYEZ3Jwc3BJZAMxNzA1MDMyMTQ0BHNlYwN2dGwEc2xrA3ZnaHAEc3RpbWUDMTUyMTgxMTI3Mw--
[14]
https://groups.yahoo.com/neo;_ylc=X3oDMTJkajJvcGs2BF9TAzk3NDc2NTkwBGdycElkAzMxODM3MDYEZ3Jwc3BJZAMxNzA1MDMyMTQ0BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxNTIxODExMjcz
[15] https://info.yahoo.com/privacy/us/yahoo/groups/details.html
[16]
mailto:Doepfer_a100-unsubscribe@yahoogroups.com?subject=Unsubscribe
[17] https://info.yahoo.com/legal/us/yahoo/utos/terms/
Re: [Doepfer_a100] Further info on the forthcoming A100 modules
2018-03-23 by Florian Anwander
Am 23.03.2018 um 16:00 schrieb blacet@blacet.com [Doepfer_a100]:
I've sold my 143-2, but as far as I remember right, they are pulses (if
they were gates: when would you expect them to end?).
http://www.florian-anwander.de
2018-03-23 by david Kellett
I think they stay high until the next cycle
D
www.movingisliving.co.uk
> On 23 Mar 2018, at 15:08, Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
2018-03-26 by yahoo@doepfer.de
The behaviour of the EOA, EOD and EOR outputs is described in detail in the
user's manual on page 2 (words + sketch)
Best wishes
Dieter Doepfer
> D
> Sent from my iPad
2018-03-29 by ross anderton
They stay high until gated again.
    On Friday, March 23, 2018, 3:00:53 PM GMT, blacet@blacet.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
On the 143-2, are the EOA, EOD and EOR signals brief pulses or do they stay high until the module is gated again or ....?
The Manual page is just a repeat of the product description.
Thanks
-------- Original Message ----------
 A voltage controlled version of the A143-2 would be amazing, especially if it had individual linear/expo switches for each of the envelopes and retained the EOA, EOD and EOR outs. In fact a voltage controlled version of the A143-1 would also be good!
    On Monday, March 5, 2018, 10:33:53 AM GMT, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
 > I'm pretty sure that is the intention, four independent ADSRs
> with a singular set of controls like most polysynths.  But I too
> am curious how the CVins will work. Seems like they would have to
> to be applied to all four envelopes at the same time and by the
> same amount.  So you could not create four separate and different
> ADSRs and, as an example, play a chord with velocity to Release
> and affect each note uniquely.  For that, one would still require
The module is planned for polyphonic applications with the same value of
each parameters for all envelopes. The control inputs of all ADSRs are
internally connected. But for DIYers it would be possi ble to interrupt the
internal connections and use separate CVs for each ADSR. But this would
require additional elements at the front panel so that the advantage of the
small 8 HP panel would be lost. We think of more new ADSRs (like the
A-140-2) and maybe we will also design another Quad VCADSR with such
additional features, e.g. master controls plus individual "variation" inputs
for each single ADSR (but not behind a 8HP panel and at a clearly higher
price). Even a voltage controlled version of the A-143-2 is under
discussion.
Best wishes
Dieter Doepfer
Yahoo Groups Links
