Doepfer
A-155 - weird behavior - needs repair?
2018-09-15 by juanvb@icloud.com
I changed my A154 A155 (2 modules) from one rack to another and I think one of my A155s broke
Something wasn't working
Ithoght it was the connection to 154 board.I connected the a-154 board to ST1 instead ST2 on the first sequencer.
It was that I had connected wrongly one of the 10 pin connectors to the board, only half of the pins was connected.
I connected everything but...
the sequencers were doing weird things
to summarize, after several trial error setups
the sequencer that was sequencer 1 when I connected wrongly does weird things
the other sequencer works ok as first sequencer connected to the A154, and if I connect both, both do weird things
I've sent a mail to hardware@doepfer.de with an explanation of what happens and I will be sending the A-155 for repair
Here is detailed explanation
A-154 with clock running and manual on/off in Off
If Faulty A-155 connected as first sequencer
I have to switch on/off twice and then the sequencer starts from step 1 to 4 then 8 then 1 and stops
If man is set as on in A-154 when I click on the A-155 module clock button
starting from step one light on
click — step2
click — step3
click — step4
click — step8
click — nothing - stays in 8
click — step1
If I connect good A-155 as first and only sequencer connected to A-154
everything works OK
If I connect good A-155 as first and faulty A-155 as second
both sequencers go to 1-4 then 8 then 1… as when the faulty one is connected as first
it seems the problem is in the A155 not in A154
any ideas??
thanks in advance
Juan
Re: [Doepfer_a100] A-155 - weird behavior - needs repair?
2018-09-17 by Florian Anwander
Hi
Am 15.09.18 um 14:02 schrieb juanvb@icloud.com [Doepfer_a100]:
click — step2
click — step3
click — step4
click — step8
click — step1
This means that the address bus high bit is some how received wrong (or interpreted wrong)
Does the A-155 work if used alone (without the A-154, configured as standalone using an external clock)? Or does it show the same behaviour?
Florian
