Doepfer
Re: Mini sequencer module ?
2018-08-09 by jacco ville
Hello, I’m building a live set up and I’m going to use the Nerdseq for its small footprint but high power to have lots of sequences and modulation.
Cheers Jacco
Sent from my IPad
2018-08-09 by 2494axe@gmail.com
Dear Jacco,
Yes, I know there are some solutions from other manufacturers (eg. crazy so short 2hp sequencer)
BUT
as stubborn as it can sound I have decided to use ONLY Doepfer modules !
A
Re: [Doepfer_a100] Re: Mini sequencer module ?
2018-08-09 by Florian Anwander
A-160/161 + 2x A-138lin + A-138u
should be the smallest Doepfer based  8step sequencer (the basic
instructio can be found in the A-161 manual)
Am 09.08.2018 um 09:22 schrieb 2494axe@gmail.com [Doepfer_a100]:
> Dear Jacco,
> BUT
> A
http://www.florian-anwander.de
Yes Florian you are right, I mentioned that solution in my first message too, but still it is pretty large, 32hp, and really limited in terms of functions.
2018-09-24 by 2494axe@gmail.com
Hello,
I've now made a patch to create an 8 step sequence using :
A147 - as trigger source
A160-161
A138a x 2 - to patch in the 8 outputs from the A161
A150-8 - to switch from the first A138 and the second one.
The /4 output of the A160 is used to switch.
The output 1 of the A161 has to be patched in the input 3 of the first A138 (and so on, output 2 input 4, output 3 input 1 of the second A138) as otherwise the switching doesn't occur at the right position and the sequence is not totally played.
I guess it is a pretty simple patch but I was just wanting to add something to that post.
Still, it takes a lot of HP for such a very simple sequencer.
All the best.
Alexandre
