Doepfer
A147-2 VCDLFO question
2018-12-25 by exakoustidismiltiadis@hotmail.com
Hello and happy christmas to everyone,
I am using an external clock e.g from dark time to sync/reset the A147-2,
as soon as I am increasing the frequency knob of the lfo, the outputs are in perfect
sync with the external clock. As soon as I am decreasing the frequency knob I have no
output signal from the lfo, the leds are not blinking. Is it a normal behaviour?
Best regards,
Miltos
AW: [Doepfer_a100] A147-2 VCDLFO question
2019-01-02 by yahoo@doepfer.de
Hello,
please make sure that the output level of the Gate/Clock/Reset/Start/Stop
outputs is set to +12V (not +5V).
And make sure that the frequency of the A-147-2 is not too low. The
frequency of the A-147-2 should be not much less than the clock signal
coming from the Dark Time. Otherwise the period of the A-147-2 is to low to
generate a noticeable signal before the next reset appears.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Dienstag, 25. Dezember 2018 19:52
> Betreff: [Doepfer_a100] A147-2 VCDLFO question
> normal behaviour?
> Best regards,
> Miltos
Re: A147-2 VCDLFO question
2019-01-03 by exakoustidismiltiadis@hotmail.com
Dieter thank you very much for your answer! No, the outputs you mentioned are +5V.
I suppose that changing the level to +12V are not going to damage the other modules, mostly Doepfer.
At first I will offset the signal of the clock output of Dark Time and I will report here!
Best regards
Miltos
AW: [Doepfer_a100] Re: A147-2 VCDLFO question
2019-01-07 by yahoo@doepfer.de
None of the Doepfer A-100 modules can be damaged with +12V gate/trigger
level.
Best wishes
Dieter Doepfer
> Gesendet: Donnerstag, 3. Januar 2019 19:45
> Betreff: [Doepfer_a100] Re: A147-2 VCDLFO question
> mentioned are +5V.
> Best regards
> Miltos
