Hi Oliver,
> Hello, I would like to put an A-118 noise/random module in my
> Paia/Blacet rig. Can the A-118 (and other modules) be adapted to
use
> my existing +/-15v. supply? Or do I need to buy a Doepfer power
> supply? Thanks! - Oliver
I can't see anything in the A-118 circuit that suggests it would not
work with +/-15V supplies. However, as a general rule I would
recommend that anyone who wants to do this checks with Doepfer first,
on a module-by-module basis, just to be sure, as there are some
modules that will definitely *not* be happy with +/-15V supplies.
(The '381 and '382 chips used in some modules will be destroyed if
run at +/-15 volts - modules using them include at least A-126, A-
130, older A-131 & A-134).
Tim
